#Camaro6
Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Miscellaneous Items
Old 03-06-2020, 01:02 PM   #1
PFYC
PFYC's Avatar
Drives: Yes
March Madness is here @PFYC!!!
MARCH is here and so is the MADNESS!! Check out these deals @PFYC!!
Custom Painted Center Console 2016-2019 Camaro
https://www.pfyc.com/custom-painted-...19-camaro.html
Give your Camaro interior a new look by customizing it with this custom painted center console for your 6th generation Camaro. We buy brand new GM center consoles, sand them smooth, primer them, paint them and put three layers of Dupont clear on top for a show winning shine. We highly recommend having a dealer install this console for you. However, If you are mechanically inclined and have some basic hand tools you should be able to change out your factory console for our custom painted console in a few hours.
Application
2016 2017 2018 2019 Chevrolet Camaro
FREE SHIPPING in the Lower 48 states! Half price shipping to Canada.
Use coupon code SAVESIX at checkout and save!!
Color Matched TwoTone Replacement Lower Grille for 2016-2018 Camaro SS
https://www.pfyc.com/CO1301.htmlhttps://www.pfyc.com/CO1301.html
Your Camaro was made to stand out, help it do so with these two tone replacement grilles. These pieces are genuine GM products, made to match your factory paint job along with adding some extra pizazz. Simple to install, this lower grille is sure to make your ride stand out from the rest of them. Be sure to combine it with a matching upper grille!
Application
2016 2017 2018 Camaro SS 6.2L V8
Cam Sport Pin Rally Stripe Kit for 2016-2018 Gen6 Camaro
https://www.pfyc.com/CO1134.htmlhttps://www.pfyc.com/CO1134.html
Our Cam Sport Pin Rally Stripe Kit for the new 2016 2017 2018 Camaro is custom patterned specifically for your model. Similar to the Cam Sport Rally Stripe Kit, the Pin version has a nice border pinstripe around the outside edges. Available for the SS hood or the smooth RS hood, just select your option. Each kit also includes the pieces for the pedestal spoiler regardless of whether you have one or not. Select from 3M, Ritrama, or Avery 2 mil high performance vinyl film, each piece is precut to fit the Camaro and requires no cutting on the vehicle. Why pay more?
Application
2016 2017 2018 Camaro Coupe
Front Bumper Mask Bra Novigo NoviStretch for 2016-2019 Gen6 Camaro
https://www.pfyc.com/FBM650C.html
NoviStretch StretchBra tm is a quality nylon bra designed for the front of your Camaro. The best feature is that this bra can be installed and removed within 3 minutes, making great for car show. Simply install it for the drive and remove it for the show!
There are three screws that hold the fender liner in place and we replace those screws with a snap head screw. So the mask snaps in the wheel well area and there are two plastic clips at the top of the mask that hook to the upper grill bar. That is the initial installation. Once that is done, simply snap in place to re-install or remove.
Folds up and can be stored right in your glove box!
This Camaro NoviMask product is "better than Vinyl or Leather and cheaper than Film" ; "Made in the U.S.A".; "backed by the manufacturers warranty and customer satisfaction policy".
We want to point out although the product is new to the 2016 Chevrolet Camaro market it has been successfully time-tested in the Corvette market for the last nine years.
This StretchBra is available in Black. We also sell the side mirror covers available in the drop down box below.
Application
2016 2017 2018 2019 Camaro
Borla 140690 Camaro SS 3" W/ Single Tips 2016-2018 Cat-Back Exhaust ATAK
https://www.pfyc.com/borla-140690-cat-back-system.html
Application
2016-2018 Chevrolet Camaro SS 6.2L V8 Automatic/ Manual Transmission Rear Wheel Drive (RWD) 2-Door (EXCEPT Convertible) equipped with Single Split Rear Exit Exhaust Non-NPP.
Corsa Xtreme Axle-back Exhaust 14784 for 2016-2018 Gen6 Camaro SS
Xtreme Aggressive Sound - If you want your 6th Gen Camaro SS to strike terror in the hearts of others as you blast down the road, you need to upgrade to a Corsa Performance Xtreme Catback Exhaust System. Acoustically engineered and tuned, this Corsa Xtreme Catback will give your Camaro SS a throaty, aggressive sound under acceleration and a deep growl at idle, all without any annoying drone while cruising. This Xtreme exhaust is for those Camaro owners who don't mind disturbing the peace.
CORSA exhaust systems feature a patented muffler design called Reflective Sound Technology or RSC. RSC technology eliminates uncomfortable sound frequencies that cause what is called exhaust resonance, or noise, inside the car at cruising speeds.
Features:
Fits vehicles with 4 tips from factory (npp cars). Does not retain dual mode at the tips
Straight-through 2.75", nonrestrictive system design maximizes airflow, improving performance and fuel economy
Mandrel bends and design deliver increased airflow vs. stock
CORSA's Patented RSC Technology allows us to acoustically style the sound of your Camaro to give you the true voice of performance without the annoying drone while cruising
All components, even clamps and hangers, of the system are constructed of premium grade, 304 Stainless Steel to ensure the look and sound of you CORSA won't change over the life of your vehicle
Proudly designed, engineered and manufactured in Berea, OH, USA
Quickly enjoy the CORSA sound with an easy bolt-on installation. No welding needed and all hardware and detailed.
Application
2016 2017 2018 Chevrolet Camaro SS Coupe 6.2L V8
2017 Chevrolet Camaro SS Coupe 6.2L V8
Show N Go Retractable License Plate Frame
https://www.pfyc.com/GN1046.html
If you live in a state that requires you to have a front license plate but you don't like the look and don't want to drill holes in the front of your car.Hide your License plate by adding the Show N Go Retractable License Plate Frame. Choose between the manual or motorized. The Show N Go retractable license plate frame enhances your vehicle aesthetics. Easily installed, stainless steel and patented robust design this product fits almost any vehicle on the road.
Do not be alarmed the approximate dimensions being 10 1/2 inches long, 12 inches wide and 1 1/4 inches high gives enough room from the ground to apply to your vehicle with no problems
Application
This is a universal fit application. Click the Installation Instructions below to see how it is installed and how it might fit your specific vehicle.
Lloyd Ultimat for Camaro 2016-2018 2pc Mats Ebony Camaro Word Logo
https://www.pfyc.com/lloyd-ultimat-f...word-logo.html
Buy your Lloyd Ultimat for your Camaro 2016-On 2 piece set of Floor Mats Ebony Camaro Word Logo with one click at PFYC and get them fast.
The Ultimat is Lloyd Mats' most popular custom floor mat line and features premium continuous filament nylon yarn for durability. The yarn weight of 32 ounces per yard is twice the weight of most factory floor mats. Check out the details below.
Application
Your Lloyd Mats always ship for FREE at PFYC! Half price shipping to Canada.
Illuminated Fuel Rail Kit for 2016-2019 Gen6 Camaro SS
https://www.pfyc.com/illuminated-fue...camaro-ss.html
Nothing says wow like LED lighting under the hood. These pieces are designed to fit all 2016-2019 Chevrolet V8 SS Camaros on the underside of the factory fuel rail covers. Choose from a variety of LED colors to fit your style.
Fits 2016-2019 Chevrolet Camaro SS model factory fuel rail covers.
Wiring installation takes 30-40 minutes.
Sold as a (2) piece set with LED Lighting
Application
2016 Chevrolet Camaro SS V8
2017 Chevrolet Camaro SS V8
2018 Chevrolet Camaro SS V8
2019 Chevrolet Camaro SS V8
FREE SHIPPING in the continental USA on American Car Craft orders over $129! Search ACCFS for qualified products.
Use coupon code SAVESIX at checkout and save/!!!
Custom Painted Hood Heat Extractor Bezels Vents for 2016-2018 Camaro
https://www.pfyc.com/16-1011.html
Give your 2016 6th Generation Camaro a new look. Our 2016-2018 Camaro heat extractors are a great way to add some pop to your Camaro's hood. We buy brand new GM hood heat extractors, sand them smooth, primer them, paint them and put three layers of Dupont clear on top for a show winning shine.You can paint these any Camaro body color or you can try our hydrocarbon fiber look. This will look like real carbon fiber without the cost.
You will not find a nicer finish on a set of 6th Gen heat extractor bezels for your 6th Generation Camaro.
Because these items are custom painted to order we do ask for additional time from order date to ship date. This set of heat extractors are painted in house. We have over 70 years combined Camaro and Corvette painting experience, you won't find better quality anywhere!
Application
PFYC is offline   Reply With Quote
Old 11-04-2022, 06:09 AM   #2
PFYC
PFYC's Avatar
Drives: Yes
Thank You for shopping at https://www.pfyc.com/FBM650C.html
