#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 03-29-2017, 01:39 AM   #1
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
Exclamation WARNING: Front end Clunk - Loose Sway Bar Endlinks (please check yours)
This happened to me after the first track event on the way back and it seems like a common issue. So far I've heard from 4-5 1LE owners saying that they heard a loud metal clunking noise/rattle from the front side of the car.
I jacked the car on my way back home to see if anything loose and thought this might be a blown strut but I wasn't sure since I knew that I never hit a pot hole or expected on a car with only 1600 miles on it. It was more noticeable when going over little bumps (when there's tension on them)
You may start reading from post #41 and 42 here:
http://www.camaro6.com/forums/showth...=484731&page=3
and video showing that (thanks to AZ_1LE for sharing the video):
In my case, upper end links on both side were loose, it seems like they're not torqued enough from factory . I searched and found that the Gen 5 endlinks torque specs were 36lb/ft torque and just torques them to 38 lb/ft with my torque wrench just to make sure.
You will need a 6mm allen key (inside the bolt) and 18mm socket for the nut that goes over the endlinks to tighten them.
I am surprised by the fact that there's no recall or TSB about this yet
glamcem is offline   Reply With Quote
Old 04-04-2017, 10:08 PM   #2
drew.87
Drives: 2017 Camaro 1LE
Thanks for sharing. I am hearing the same sound. Going to take it to get fixed.
drew.87 is offline   Reply With Quote
Old 04-04-2017, 10:11 PM   #3
glamcem
glamcem's Avatar
you're welcome, I am glad this was an easy fix. It was driving me nuts
Old 04-11-2017, 01:38 PM   #4
glamcem
glamcem's Avatar
moving to the top so everyone can see and check this
Old 04-11-2017, 02:40 PM   #5
slick3
Drives: Garnet Red - 20 ZLE
Thanks for the tip. Next time I have the wheels off I will check mine just to be sure. Considering it sounds like both our cars were built on a Friday
slick3 is offline   Reply With Quote
Old 04-11-2017, 03:42 PM   #6
glamcem
glamcem's Avatar
I know right? NP btw
Old 04-20-2017, 11:18 PM   #7
slick3
Jesus, my left front was finger tight....thanks for heads up.
Old 04-21-2017, 01:12 PM   #8
glamcem
glamcem's Avatar
You're welcome
Old 04-21-2017, 01:29 PM   #9
2K16SummitSS
Resident Land Surveyor
2K16SummitSS's Avatar
Drives: 2016 Camaro 1SS - Summit White M6
I don't have a 1LE, but I am getting a clicking/tapping noise on the front end driver side, especially on tight right turns. This is with normal driving, no track time. I will have to check this out. I may opt to take it to the dealer just so they can log it in the system and maybe help to get a TSB out at least.
2016 Summit 1SS 49th Anniversary Commemorative Limited Plutonium Edition - M6, Solo Axleback & !RearCats, Ultra-Rare Cloth Seats, Forgestar CF5V 19x10-285/35 19x11-325/30
2001 NBM Trans Am WS6, Wifey's Grocery Getter - Torquer V2 cam, Racetronix Fuel Pump, Yank 3000 Stall, Transgo 1-2 kit, TSP LTs, Magnaflow, Strano Springs/Koni STR.T shocks, 17x9.5/17x11 TTIIs, Ed Wright tuned
2K16SummitSS is offline   Reply With Quote
Old 04-21-2017, 03:12 PM   #10
glamcem
glamcem's Avatar
So far I only heard from the '17 1LE owners but it may be worth checking for sure
Old 05-08-2017, 12:25 PM   #11
Tara Martin
Loves Camaros
Tara Martin's Avatar
Drives: Red '79 Z28, '21 Red Hot M6 ZL-1!
My ZL-1's doing it, too. I'm going to try to check it after work against the OP's video. Thanks glamcem!
Old and new, sharing space!
Tara Martin is offline   Reply With Quote
Old 05-08-2017, 12:49 PM   #12
glamcem
glamcem's Avatar
you're welcome
Old 05-08-2017, 01:05 PM   #13
2K16SummitSS
After some looking, finding nothing wrong visibly as per the above video, and doing some additional research, I believe my problem is the one from this thread....
http://www.camaro6.com/forums/showthread.php?t=492064
Old 05-08-2017, 01:17 PM   #14
00 Trans Ram
00 Trans Ram's Avatar
Drives: 2017 2SS
I have a regular 2SS, and my left front endlink was the same way. Heard a clunk over bumps with the left front at first. Then, it progressed to be either front tire.
Got under the car with the right front jacked up, but nothing seemed loose. So, I took it to the dealership. They reported back and initially said that they could find nothing loose, but could hear the noise.
Later in the day, they said they'd found the loose endlink. Evidently, with the wheels hanging free, there was no play in the endlink. But, when the weight of the car was on it, it would be loose. They only found it when they put it on a drive-on lift. Couldn't see it on a regular 2-post lift.
So, if have this problem and can't find it with the car jacked up, try it with the car on the ground.
00 Trans Ram is offline   Reply With Quote
