02-13-2018, 07:50 AM | #1 |
Drives: 2012 45th Anniversary Join Date: Oct 2014
L99 to LS3 Kit
I was going to do a cam on my L99 and get rid of all the VVT but have since changed my mind. This includes everything you will need except a cam, valve spring kit, and pushrods. All these parts are brand new from Local GM Dealer. I will not sell anything separate.
$750 DOD Parts: (1) 12599296 LS3/LS7 Valley Cover (4) 12595365 LS2 Lifter Trays (1) 12599298 GM PCV Hose (2) 12610046 LS3 Head Gaskets (2) 17800568 GM Head Bolt kit (1) 12557840 GM Crankshaft Damper Bolt (1) 12499225 GM LS7 Lifters (1) 12585673 GM Timing Cover Seal (1) 12633904 GM Timing Cover Gasket (2) 12637683 GM Valve Cover Gaskets (2) 12630223 GM Water Pump Gasket (1) 12588670 LS2 Timing Chain Dampener (1) 12594779 LS6 PCV Hose (1) 19256623 Intake Gasket Set VVT Delete: (1) 12600362 Front Timing Cover (1) 12627501 Cam Sensor Harness (1) 12591720 Cam Sensor (8) 11515758 Timing Cover Bolts (1) 11588712 Bolt (1) 12586481 Sprocket (3) 12556127 Bolts (8) 41-110 GM Spark Plugs (1) Gallon of GM Coolant |
02-20-2018, 02:02 PM | #2 |
$650
02-20-2018, 02:18 PM | #3 |
Drives: 2011 2SS/RS Camaro Join Date: Sep 2017
You should be able to return the parts to your local dealership for a complete refund if unable to sell on the forum.
07-26-2018, 03:03 AM | #4 |
Drives: 2011 Camaro 1SS L99 Join Date: Feb 2017
Still available ?
