Old 05-19-2020, 08:06 AM   #1
jimmyducati
Drives: 01 SS Camaro
Stage 4 BTR cam for "daily driven" M6?
Im about to pull the trigger on a '13 ZL1 with a BTR Stage 4 cam and supporting mods (appropriate valve train, CAI, Kooks headers, 1000cc injectors, heat exchanger upgrade etc). Car will be a daily driver with a 50/50 mix of highway and city.
My concerns are the drivability and dare I say economy... I know we don't buy these cars to save money at the pump, but I don't think I could live with 10-12 mpg either.
Also, I see Gen 5 ZL1's go for anywhere from high 20's to high 40's. I know that being a kinda special version of the Camaro, KBB is likely way off on its valuation. What should someone pay for a low mileage example of a ZL1? I don't really consider mods to be value adders, so Im not taking that into consideration.
jimmyducati is offline   Reply With Quote
Old 05-19-2020, 12:51 PM   #2
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
That screen name is familiar...
Old 05-19-2020, 01:19 PM   #3
lgarrison34
lgarrison34's Avatar
Drives: 2017 SS 1LE HBM, 2010 SS FBO/Cam
I have a TSP Stage 4 F35 cam in an M6 SS FBO. You will be in the 10-12 mpg range and that's if you're keeping your foot off the pedal.
lgarrison34 is offline   Reply With Quote
Old 05-19-2020, 06:58 PM   #4
DrkPhx
DrkPhx's Avatar
Even stock these cars don't get good gas mileage, so with mods (especially a cam) it can get worse depending on the tune. If you're even slightly worried about driveability and mpg and you've never driven a cammed car; you may not like it. You really need to test drive it. I have a baby cam in mine and it still puts down great power and drives great.
Old 05-19-2020, 09:43 PM   #5
jimmyducati
Louisville sport bike perhaps? I’m not there a lot, but that could be it.
Old 05-19-2020, 09:49 PM   #6
jimmyducati
Im driving to see it in the morning, wouldn’t buy something like this without a test drive! I knew even mentioning mpg’s would draw fire, I get that these cars get terrible mileage, but there shouldn’t be anything wrong with trying to make power efficiently. since I have no experience with an LSA, I would be an idiot to not inquire about what I should expect, especially a modified car!
Old 05-19-2020, 09:58 PM   #7
DrkPhx
DrkPhx's Avatar
^^^ True. I get better mpg now compared to stock when hwy cruising.
Old 05-20-2020, 03:52 AM   #8
Vicster
1000hp is NEVER Enough!
Vicster's Avatar
Drives: 13' ZL1
Stage 3
I run something close to a stage 3 and over drive supercharger 41%. Lots of mods... drives nice as daily driver, 22mpg on highway, but give it some throttle and the monster comes to life!
More on my journal...
Vicster is offline   Reply With Quote
Old 05-20-2020, 08:54 AM   #9
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I agree. I get 16.5 mpg on mine driving back and forth to work daily on country backroads- mostly 35-55 mph, with a bunch of stoplights and stop signs.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides-
2014 ZL1 M6 Red Hot | Tons of mods
2004 CTS-V M6 Silver | Many mods
1995 Corvette M6 Torch Red | A few more mods
1992 Camaro M5 White | A few mods
RobZL1 is offline   Reply With Quote
Old 05-20-2020, 10:50 AM   #10
jimmyducati
16.5 is more than I expected so that makes me happy! I’m not familiar with the guys who tuned it, so I’m going to have a new tune done at raceproven in Kentucky. I’ll try the stage 4 out for a while and if it’s not comfortable on the street I may go with a smaller cam.
Thanks for the replies guys!!
Old 05-20-2020, 12:56 PM   #11
Little Walter
Drives: ZL1
I get 22 mpg cruising on the interstate at 78 mph with a .646 lift cam, heads ported, cold air with 2.55 upper pulley and 9.55 lower, ARH 2 inch headers cat delete. Auto Trans. Much better than when it was stock.
Little Walter is offline   Reply With Quote
Old 05-20-2020, 02:12 PM   #12
jimmyducati
Thanks!
If driven with a light foot, any car with a really good tune should become more efficient, even with a ton of mods. They usually don't because they are so much more fun to drive fast!
Old 05-20-2020, 02:38 PM   #13
GONMAD510
Drives: 2013 ZL1 M6
Originally Posted by jimmyducati View Post
Thanks!
I barely get double digits mostly because my commute is mostly city streets. Plus I like to have fun in this car.
Fast 850cc Injectors, ATI Balancer, 8.66 Lower Pulley, 2.55 Upper Pulley, Lingenfelter CAI, Kooks LT with cat delete pipes, Noweeds Exhaust Cutouts (extremely loud under full throttle), BTR Stage 3 Cam, BTR Platinum 660 Valve Spring Kit, TR7ix Iridium Spark Plugs, Lingenfelter Solid Isolator, 160 Degree Thermostat, Larger SC Coolant Reservoir with Hose Relocation Kit, BMR 1.25" Lowering Springs, MGW Short Throw Shifter, Racing Brake 2 piece rotors front and rear, Starkweather Performance Custom Dyno Tune on 91 Octane.
691.38 RWHP
630.35 RWTQ
GONMAD510 is offline   Reply With Quote
