06-30-2014, 05:44 PM | #1 |
Drives: Black 2012 ZL1 Join Date: Mar 2013
LS9 cam
Let's talk LS9 cam..........
I think it's the route I want to go, so I have a few?s Are new springs needed? I haven't been able to find a definitive answer on this. What else besides the cam (and maybe springs) is needed? Will it need a tune after? |
06-30-2014, 06:42 PM | #2 |
Going for Plaid
Drives: 2011 C6 Join Date: Jan 2010
Springs: I would.
Pushrods: I would. Tune: Yes. Think about Brian Tooley or Comp Cams rocker trunnion upgrade for your stock rockers. The stock rockers are light. Light is good. The needle bearings in them have been known to exit the rockers though. The upgrade takes care of that potential issue. I would also do a C5R timing chain while you are swapping the cam. I snapped a stock LS3 chain in my C6. That was expensive. Also a good time to change your stock balancer with an ATI or Innovators West since it has to come off anyway.
2014 ZL1, manual trans, carbon hood insert, Rotofab, Pacesetter 1 7/8" headers, 1" drop BMR springs, stock pulleys, 91 octane tune, 545rwhp & 515rwtq
Serviced and modded by Cordes Performance. 2011 C6, 750rwhp, forged LS3, ported LSA heads, Vortech Ti-trim, 227/243 115+4 Lunati cam, ported LS3 intake, Alky Control methanol, Pfadt sways/shocks/trans mounts, Pfadt tri-y headers(Sold 6/28/14) |
06-30-2014, 07:36 PM | #3 |
Drives: 2013 ZL1 Join Date: Mar 2013
Would the LS9 springs be ok? Is the LS9 cam a 3-bolt cam? What pushrods?
2013 ZL1
06-30-2014, 09:25 PM | #4 |
Is a C5R chain necessary in the LSA? I know it's popular for the LS2/3.
New pushrods for the LS9 cam??? I didn't think it was a big enough cam to need those. |
07-01-2014, 10:20 AM | #5 | |
Going for Plaid
Not sure if it's necessary, but it's good insurance. I broke a timing chain. If I change my cam it's getting a C5R chain. If you raise you RPM limit I would do pushrods and better springs. Valvetrain stability is very important.
07-01-2014, 11:34 AM | #6 |
I was curious if the C5R is any stronger than what is already in the LSA since the LSA already has 580 HP. I know for the LS2/3 it makes a difference.
07-01-2014, 09:56 PM | #7 |
Drives: none Join Date: Oct 2012
I think this is good value if going with the LS9 cam for $455 per head.
Intake valve are titanium http://www.jegs.com/i/Chevrolet+Perf...57324/10002/-1 |
