Old 09-11-2016, 02:59 AM   #1
LastGen5
Manual Guy - Until Now...
LastGen5's Avatar
Drives: 2018 ZL1 A10
Minimum Whipple pulley size for 6 rib belt
Sorry if this information is somewhere else on the site - if so, I couldn't find it.
I am wondering what size Whipple pulley I can run on the 6 rib belt. I'm pretty sure 3.875 is okay but not sure about 3.75.
Anyone with some real experience with this?
LastGen5 is offline   Reply With Quote
Old 09-11-2016, 04:56 AM   #2
Kiwi_Camaro_2010
Kiwi_Camaro_2010's Avatar
Drives: Camaro 2SS/RS 2010 L99
I've used 3.625" on 6 rib with no slippage, had to use smaller dia belt & adjust pulleys, I have a 3.375 I'm gona try next at next meet.
Camaro 2SS/RS 2010 / L99 / Whipple SC /Dynatech Headers & Catts (gutted), ID 850 injectors, ZL1 fuel pump +BAP & ADM pump controller, ZR1 3Bar MAP, Dual Elite Catch Cans, 91 octane ,Eibach sway bar kit , Driveshaft loop, oil cooler delete, ADM dual gauges (AFR/Boost) LC1 wideband controller, D/D, ARP stud kit ,Callies forged slayer crank 3.622", callies ultra rods, wiseco forged pistons, L99-LS3, rollmaster double row steel timing set & comps cam timing cover,blower cam 630/660 lift,3/8 pushrods, pac gear 8deg, yella terra ultra lites. LS9 head gaskets. Texas speed custom oil pump. Asm by me.
Kiwi_Camaro_2010 is offline   Reply With Quote
Old 09-11-2016, 05:12 AM   #3
LastGen5
LastGen5's Avatar
That's perfect - thank you. My motor is still stock hence won't be going that small on the pulley, but it is good to know that I could go a bit lower without spending more $$ on an 8 or 10 rib setup.
Old 09-11-2016, 09:20 AM   #4
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
I have been running 3.75 pulley with the six rib over 4 years. With many WOT pulls on it and no slippage.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 09-11-2016, 10:42 AM   #5
avido
Drives: camaro ss\rs
I used the 3.750 with slippage I think because of the belt size. I just got a 3.625 and a shorter belt. I'love try soon and we will see
2014 camaro SS Whipple powered ,3.750 pulley,ID850, CAI,Flowmaster American Thunder exhaust,MGW racing shifter,Bo White ported tb,MightyMouse Catch Can,Vitesse throttle controller,GM 3.91 rear end, Dynatech longtube haders, BTR Pd cam,Fluidampr stock pulley,ZL1 fuel pump and ADM fpcm, Phastek scoop and fluid thank relocation Bmr Motor mount . Tuned by Mastuning
avido is offline   Reply With Quote
