Old 11-20-2015, 07:56 PM   #421
Mgizzle
Mgizzle's Avatar
Drives: 2013 Camaro 1LE 1SS
Jordan is spot on with monoblock vs. 2 pc calipers. After some hardcore tracking the two pc will simply leak. Those two surfaces move under temperature, especially if you have air blowing on the inside half but none on the outwards due to rim.
I still dont understand why nobody runs the AP racing Radicals for same money as this two pc, smaller brake system?!? Two pc caliper for $3800........hmmmmmm
Wow...just realized they use same pads so same surface area and lower rotor ring mass?!?!?! So less heat sink in system.....equals higher pad temps equals more pad fade. I dont think this system will perform better than the OEM 6 piston....not even close to the radical system.
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
Mgizzle is offline   Reply With Quote
Old 11-20-2015, 11:30 PM   #422
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
I've struggled with upgrading to a 6-piston setup for a long time, but since installing my front brake ducts, I have had ZERO issue with overheating the brakes.
The Brembo SS stock calipers are just fine for your typical track day use. They are super easy to swap out the pads too. However, I must say that we never experience extremely hot days here in Vancouver.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 11-22-2015, 11:22 AM   #423
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
