08-22-2014, 07:56 AM | #1 |
Rattling front passenger wheel well
Hello! So I have been noticing for a little while that in the morning (or when my car is cold), as soon as I start accelerating I heard a rattling at where seems like the passenger side front wheel well. It sounds like there are a bunch of rocks getting caught up in the wheel well (there obviously isn't), more of like a crackling noise I guess. It is only around at low RPM's, in gears 1-3, when accelerating, and again when cold. By the time I make it down to the main road, about 3/4 of a mile, it stops all together and then I don't hear it again until the car has been sitting a while and I start to accelerate. Any ideas? Thanks!
08-24-2014, 02:34 PM | #2 | |
Drives: GM Vehicles Join Date: Jun 2010
William R. Chevrolet Customer Care |
11-28-2014, 09:27 AM | #3 |
Drives: 2018 ZLE Join Date: Jul 2014
ever get an answer or solution?
05-22-2020, 05:10 PM | #4 |
Sancho the Camaro
Drives: 2015 Camaro 1LT Red Rock Metallic Join Date: Jul 2015
I'm also having this issue. Did you ever get an answer?
05-22-2020, 06:07 PM | #5 |
Drives: 2015 Z/22 Join Date: Aug 2015
I don't have the same thing but do notice that on a cold start I hear a bit of a rattle in the front, but it only last for a few seconds, gone before I start driving. Sounds like a heat shield vibrating/touching something. Just got my high-flow cats put on and didn't notice the rattling (although only had one cold start since). Perhaps the heat shield around the driver's side down pipe? Could shove some rags in and around it and start the car, see if it goes away (and remove rags before they burn up ).
05-22-2020, 07:27 PM | #6 |
Banned
Drives: cheby Camaro Join Date: Aug 2019
Most likely the cam phasers not locking up properly.
