07-13-2010, 11:19 AM | #1 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2010
tune it or not?
I have an SS with exhaust and intake.... How much horesepower should I expect to gain from a tune? I want to know if it is worth spending 500 on a tune. Also does anyone have an idea what the total RWHP would be? Thanks guys
07-13-2010, 11:38 AM | #2 |
$500 ??? no... that's high...
07-13-2010, 11:51 AM | #3 |
ya thats the going rate up here in nor cal.
07-13-2010, 12:20 PM | #4 |
Drives: 2010 Red SS/RS Join Date: Jul 2009
If you have the A6, then its definitely worth for the transmission portion of the tune.
07-13-2010, 01:17 PM | #5 |
Drives: Firehawk Join Date: Jun 2009
07-15-2010, 08:07 AM | #6 | |
The Exhaust does not play a role in Tuning or Horsepower. There is typically around 5-10 HP in the Tune but with the torque management it feels like a lot more especially in the lower RPM ranges where you drive most of the time. A Tune Really Wakes up any combination. You don't have to spend 500 on a tune, I Provide the tune for free when you buy the hand held tuner from me. Ted.
www.jannettyracing.com
07-15-2010, 10:10 AM | #7 | |
So, how much torque management do you set your tunes at, 0.75, 0.5, 0.25, 0.00? Since 1.00 is stock. What are the trade offs as torque management is reduced? |
07-15-2010, 11:19 AM | #8 | |
Torque management does not make the transmission shift any harder, what it does is Suck the Ignition timing out during shifts to reduce torque the engine produces. If your in to performance you don't want any timing pulled during shifts or any other events. Ted.
07-15-2010, 12:48 PM | #9 |
Are you refering to the SCT tuner that torque management is only on or off? I know that at least HP Tuners and VMS can set it anywhere between 0% to 100% torque management.
07-15-2010, 01:50 PM | #10 | |
It is not like a Sliding rule, where you can move the cursor and select the percentage of torque management. There are maximum allow torque tables that we can raise or lower for each gear, and that is only once it is in gear not during a transition from one gear to another. For example 1st through 4th gear is limited to 900 Nm from 500 to 3000 RPM, but 5th and 6th gear are limited to 705 Nm. This still does not affect how much timing is pulled out during a shift. We can either allow Trans torque management or not from what I can see. Ted.
07-15-2010, 03:16 PM | #11 |
Drives: 2010 Camaro 1SS/RS LS3 blck w/ IOM Join Date: May 2010
I want a tune but I don't fully understand it. If I buy a handheld tuner from janetty, do I just give some info about my car and they send me the handheld with a preset tune based off my mods and just plug it into some computer harness in my car? I found an sct tuner that saves your stock tune, can this be used to change back to stock tune and dealers will never know you ever tuned it? I'm partly worried about fully voiding my warranty :\
07-15-2010, 03:27 PM | #12 | |
I write your tune and email it back to you, Save your Tunefile.CEF to your desktop, then You connect your X3 to your Computer once again, LOAD CUSTOM TUNE FILE, when finished, Connect to your car and Program with JRE tune, and go have some fun. The Tuner Saves a copy of your Stock File automatically and you can RETURN TO STOCK anytime you like. Ted.
07-15-2010, 03:44 PM | #13 |
ohhhhhhh Ted you are camaro5's favorite.
07-15-2010, 03:49 PM | #14 |
Similar Threads | ||||
Official 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 3652 | 08-17-2023 02:50 PM |
Pre-Camaro5FEST, FREE DYNO & TUNE SPECIAL!! | Qwkss | USA - Great Lakes | 1 | 01-27-2010 11:19 PM |
Pre-Camaro5 FEST, FREE DYNO & TUNE SPECIAL!! | Qwkss | USA - Southeast | 1 | 01-27-2010 11:17 PM |
Tune now or tune later | brtaus | Tuning / Diagnostics -- engine and transmission | 1 | 01-27-2010 12:20 PM |
Lets play a game | 2SSRS@Gen5diy | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 56 | 09-26-2009 09:08 AM |
