05-03-2011, 10:20 PM | #1 |
Reinstalling Trans
Okay so my friend and I took the trans out to swop the clutch and eveything but now we cant get the f'ing thing back into place to save our lives!! we have it sitting one a floor jack and its all lined up, like we can get the input shaft into place a little where we cant turn it from the back(where the drive shaft goes) but it just wont go any farther. We checked and rechecked with the alignment tool to make sure it was all in place but still no luck. Anyone with some idea of what could be causing this? the gap thats left is about half an inch or so...
05-03-2011, 10:38 PM | #2 |
Drives: 2015 ZO6 3LZ Stage 2 A8 Join Date: Nov 2010
ive heard that you have to tilt the motor to get the tranny back in, try unbolting the motor mounts, (with a jack under it) and lower the motor a few inches. might want to replace the rear main seal before you put it all back together. TSB on them, which mine is leakig oil. its one of them things, while your in there, might as well replace it
05-03-2011, 10:42 PM | #3 | |
Tyranny is Closing In
Drives: 2010 Camaro SS Join Date: Apr 2011
Also, I assume you used a clutch alignment tool before tightening down the pressure plate? |
05-04-2011, 04:39 AM | #4 |
Jack up the motor and twist the trans to the right about 45 degrees. This will give you just the clearance you need for the bell housing. Once you slide it forward about 2" you can straiten her back out.
Similar Threads | ||||
2011 Chevrolet Camaro - Conversion to HPP T/A Trans AmHigh Quality 69 Pontiac | Kman 2011 ss | 5th Gen Camaro SS LS LT General Discussions | 34 | 03-26-2011 11:33 AM |
PWA "The Lounge" | DGthe3 | Off-topic Discussions | 143773 | 11-06-2010 11:00 AM |
Phoenix T/A - New Trans Am concept based on 2010 Camaro | 2SSRS@Gen5diy | 5th Gen Camaro SS LS LT General Discussions | 152 | 07-13-2010 07:32 AM |
Over 230 Satisfied 2010 Camaro Customers! Paddock Chevrolet has 40 in stock NOW | camarojoe | Dealer Camaros for Sale | 2 | 05-24-2010 05:58 PM |
Kevin Morgan Concept TA Unveiled | nUcLeArEnVoY | General Automotive + Other Cars Discussion | 66 | 09-07-2009 08:33 AM |
