Old 09-01-2012, 06:25 PM   #1
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Cool Finished Installing my QUAD 4" tips, SOLO Axleback, and Modified stock diffuser Pics!
Installed he SOLO axleback, quad 4" angled, beveled, staggered tips, and I modified the stock diffuser with a dremel. I plan to get the ZL1 diffuser eventually, so the diffuser is temporary.
SOLO sounds really good, and I love the quad exhaust look. I might eventually move the tips back a little, thanks to the SOLO system being clamped on I can always adjust it, cut more of the old system off and slide it back and inch or two. But I had everything put on to fit the ZL1 diffuser perfectly, so when I get it, everything should fit fine.
These are just some iphone pics, enjoy.
Old 09-01-2012, 06:30 PM   #2
Run4two
Run4two's Avatar
Drives: 2012 Camaro 2SS Transformer Edition
Damn nice!!!
Run4two is offline   Reply With Quote
Old 09-01-2012, 06:38 PM   #3
blade_ss
blade_ss's Avatar
Drives: '12 AGM 2SS/RS M6 & 05 Mazda3
looks awesome. How difficult was the install?
blade_ss is offline   Reply With Quote
Old 09-04-2012, 08:26 AM   #4
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Originally Posted by Run4two View Post
Damn nice!!!
Thanks!
Thanks,
The whole thing took me about 3-4 hours if I remember correctly.
1. First I installed the axleback, I ordered it without tips from SOLO. As long as you can lift the car up enough to have room to be comfortable, its easy. Mark the pipes, cut off with a sawzall, and work the old exhaust off. Slipping the old one and putting the clamps is easy as well, no leaks whatsoever.
2. Modifying the diffuser, this was kind of a bitch. Using a dremel, looking at tons of pics online of others diffusers and measuring, making a template and actually cutting took time, and then using sandpaper to clean up the edges. If you have done anything like it before, it wont be terrible, but isn't for everybody.
3. Welding the tips on and centering them, I left this to a professional, and it cost 50$ per side, and came out dead even.
The hardest part was messing with the diffuser, I would recommend if you have the money to get a ZL1 diffuser or buy a modified stock diffuser at the same time. I plan to do the ZL1 one eventually.
Old 09-04-2012, 08:57 AM   #5
pierre777
HT5 COTW 9/3/2012
pierre777's Avatar
Drives: Cyber Bullet
looks killer awesome brotha ,good work.
Old 09-04-2012, 09:11 AM   #6
babytiger
it's hers...
babytiger's Avatar
Drives: 2011 Camaro 2SS/RS Convertible
When you say "move the tips back" do you mean tucked in more? If so, I think they look good where they are.
When I had mine put on I had them extended out further than stock. Looks better IMO.
babytiger is offline   Reply With Quote
Old 09-04-2012, 09:37 AM   #7
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Thanks
Yeah, I was thinking about having them tucked in more. But Im leaning more towards what you are saying, since the stagger on the tips, isnt as extreme as the angle of the bumper, moving them back at all will completely hide the inner tip.
Its a trade off, do you want it to look better from the side, or from the top.
I think standing at the trunk looking down, they look perfect, but from the side, sometimes they stick out too much. Either way I dont think im going to adjust them. When I get the ZL1 diffuser, ill see if it changes anything
Old 09-04-2012, 09:47 AM   #8
BAD DAB
BAD DAB's Avatar
Nice work!
Old 03-16-2013, 11:13 AM   #9
AC
***GO HOGS GO***
AC's Avatar
Drives: 68/327 & 10 2SS SIM w/ CGM Stripes
looks great!
ProCharger F1A, ID1000 Injectors, SW Headers, SW full 3" Exhaust, BMR Suspension, CCW 10"/11.5", DBA Rotors, 3.91's, 560/570 hp/tq
ProCharger F1A, VMax TB, ID1000 Injectors, SW Headers, SW full 3" Exhaust, BMR Suspension & 4 Point Strut Tower Brace, 3.91 Gears, DBA Rotors
Heritage Grille, CCW SP16a Wheels 10"/11.5" Nitto 275/40 315/35, Painted Calipers, Blackout: Bowtie, Rear Panel, Markers & Side Vents,
SS Fender Badges, 6.2L Cowl Lettering, Pistol Grip Shifter, RPI SS Door Kick Plates, Billet Cup Holder, Fesler Shift Boot, Lloyd Floor Mats..(1/4: 12.917 @ 109.63)
AC is offline   Reply With Quote
Old 03-17-2013, 06:02 PM   #10
Bullcefus
Drives: Summit White 2013 SS
Looks awesome
Bullcefus is offline   Reply With Quote
Old 03-17-2013, 06:53 PM   #11
KidKilowatt
KidKilowatt's Avatar
Drives: 2011 Camaro 2LT RS
Which tips did you buy??? And from where? Looks great BTW !
2011 LLT RS Black on Black Loaded. [x]Showstopper 45th Anniversary inspired Camaro RS Stripes, [x] MPD1 Spoiler, [x] GM Heritage Grille. [x] Removed RS and Bowtie Emblems. [x] 30% Tinted Headlight Armour DRL's. [X ] Ruff Racing R954 Wheels [X] Solo Cat Back Mach X-LLT Exhaust [X ] Vmax Ported throttle body [x] Halo SC Reverse Hood Kit [x] Showstopper Painted, Modded Engine Cover [x] Cold Air Inductions CAI [x] Tinted Tails and Black Bezels [x] Megan Racing Street Series Coilovers [x] Belltech F&R Sways
Check out my build thread!
http://camaro5.com/forums/showthread.php?t=212178
KidKilowatt is offline   Reply With Quote
Old 03-17-2013, 08:22 PM   #12
TStko
TKO
TStko's Avatar
Drives: you crazy...
nice nice nice work!!!
Also like the pin stripes on the wheels
1100-Preliminary Order Accepted 10/13/2008
DELIVERED- 5/29/09
cars are like women, some are old, some are new, some get turned on easily some need a lot more help, some you just wanna drive into the river, some you can't wait to get inside of, some are expensive to maintain, some are low maintenance, however if you treat them right, you'll have her for the rest of your life.....
TStko is offline   Reply With Quote
Old 03-17-2013, 10:35 PM   #13
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Thanks! I appreciate it!
Old 03-17-2013, 11:01 PM   #14
Vengeance Graphix
Vengeance Graphix's Avatar
very nice!
