#Camaro6
AWE Tuning
Old 06-23-2016, 04:00 PM   #1
Ace01
Ace01's Avatar
Drives: 2018 1LE SS "Silver Bullet"
2016 Chevy Camaro Exhaust & Headers (Before & After)
http://stainlessworks.net/2016-chevy...st-and-headers
Ace01 is offline   Reply With Quote
Old 06-25-2016, 05:31 AM   #2
Ace01
Ace01's Avatar
Old 06-25-2016, 09:30 PM   #3
GrimReaperSS
Drives: 2001 Onyx Black/Ebony SS. 427/M6
I feel like just the SW Axle back exhaust sounds the best of those videos. To each their own....
GrimReaperSS is offline   Reply With Quote
Old 06-26-2016, 08:29 AM   #4
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
I agree. Not sure if it was the video, or if it is really the way it sounds. I see the dB is quite a bit higher as you add the entire cat back and then headers and cat back, but the sound was best to my taste with just the axle back.
16 Red Hot 2SS A8: NPP, CAI Cold air, Ported TB, Fasterproms Ported intake, E85 flex, Formatto tuned. 11.80@118 with 1.92 60' (600-700 DA) on stock run flats.
jdasnt3 is offline   Reply With Quote
Old 06-26-2016, 08:38 AM   #5
bbrown450
bbrown450's Avatar
Drives: 2016 Mosaic Black 2SS
The piece that is welded inside their X pipe that sledgehammer refers to that he is unsure of was called out in the SW video as a "cone" that makes sure that the flow into each pipe is uniform ...does not have anything to do with drone ...fyi
Originally Posted by Ace01 View Post
bbrown450 is offline   Reply With Quote
Old 06-26-2016, 09:12 AM   #6
TheCaptain
N7 Spectre
TheCaptain's Avatar
It all really sounds awesome!
Old 06-26-2016, 02:32 PM   #7
paul84043
paul84043's Avatar
Drives: 2015 Camaro 2SS RS 1LE
Not sure why you'd bother adding headers to the '16, it comes with Tri-Y shorties stock which pretty much accounts for the power increase over the Gen5.
Unless you need the high end power, shorties are actually better for the type of driving most of us do.
Probably the largest improvement would be High Flow cats, the stock exhaust breathes exceptionally well as it is.
Someone posted a video of a shop adding Hooker Tri-y shorties, the process was kind of a pain and the ultimate "gain" was a whopping 8 HP which is noise level on a Dyno.
paul84043 is offline   Reply With Quote
Old 06-26-2016, 03:25 PM   #8
oldman
Drives: SS 6 speed of course
actually prefer the SW header with factory exhaust during actual acceleration and interior levels.
Forged short block, large duration sub .600 lift Cam Motion cam, 7200 RPM fuel cut, Pray Ported Heads, 3.85 pulley D1X, stage II intercooler, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0 pump, ported front cats, 60608 Borla, LT4 injectors, ZL1 1LE driveshaft and Katech ported TB, ported MSD intake, BTR valvetrain, ARP studs, ProFlow valves, PS4 tires.
oldman is offline   Reply With Quote
