Old 10-25-2010, 09:55 PM   #1
HokieERVet
HokieERVet's Avatar
Drives: SIM/2LT/RS/Black/Manual
Mobile 1 75w-90 LS question (V6)
Has anyone put Mobil 1 75w-90 LS gear oil in a V6 manual transmission?
I was about to use it as it says it meets GL-5 requirements (and also my differential) but I just read a post on here somewhere saying that I should not have any friction modifier in the transmission (an NS option which I don't think Mobile 1 has).
Will the Mobil 1 75w-90 LS hurt the transmission?
Thanks,
Chris
PS- I know this should probably be in Maintenance section but I was hoping to get a few more reads in this section.
HokieERVet is offline   Reply With Quote
Old 10-25-2010, 10:07 PM   #2
jtzako
Drives: 2010 IBM Camaro SS
The LS gear oil is for the rear differential, not the tranny. I dont know if it is even the right stuff for transmission. I used it in my rear diff but still needed the friction modifier additive to make it work right.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 10-26-2010, 10:09 AM   #3
HokieERVet
HokieERVet's Avatar
ok- so I'm thinking
Oil- Mobil1
Transmission- RedLine 75w-90 NS
Differential- Mobil 1 75-90 LS +/- the friction modifier
Or am I stuck only using what the dealer sells?
Thoughts anyone?
Old 10-26-2010, 12:32 PM   #4
jtzako
For the Engine Oil and Diff those would be fine. I dont know about the tranny since I dont have a manual transmission. There's no reason to use what the dealer sells as long as you use stuff that meets GM specs.
Old 03-12-2011, 09:43 AM   #5
esperman
You Can Call Me Jay
esperman's Avatar
Drives: 2010 1LT RJT Manual w/CAI & Solo
well, I just put Mobile 1 75W-90 LS oil my my Asian AY6 tranny. I've heard you still have to add LS additive if you use this oil in the rear diff. Theoretically it should work fine for the tranny, as GM specs GL5. But I'm staring to wonder if the GL-5 spec oil could be a problem for this transmission.
esperman is offline   Reply With Quote
Old 03-13-2011, 12:24 PM   #6
esperman
You Can Call Me Jay
esperman's Avatar
update-
decided to drain out the Mobile 1 and put in Red Line 75W90 NS GL-5 instead. I think the limited slip additive in Mobile may cause harder shifts.
Old 03-13-2011, 12:48 PM   #7
Russell James
Russell James's Avatar
Correct, you don't use LS gear lube in the AY6 trans. Just GL5 spec 75w90.
Old 03-19-2011, 08:11 PM   #8
esperman
You Can Call Me Jay
esperman's Avatar
happy with Red Line 75W-90 NS gear oil. Did some upper 6K fast & hard shifts...feels better. No grinds into 2nd. However, the only time I would occasionally grind 2nd was when traction control was turned off. Didn't get a chance to test that scenario, but the tranny does feels smoother with the new syn oil.
Old 03-19-2011, 08:30 PM   #9
2010 2SS RS
Drives: Metalic Silver 2010 Camaro 2SS RS
update-
Don't let GM know ... they won't cover your warranty if u use royal purple or redline along with many other top performing brands ...
2010 2SS RS is offline   Reply With Quote
V6 LS LT Front Spoiler GFX Dynabyte Exterior Parts & Accessories 12 07-07-2010 12:09 PM
v6 top speed ihc95 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 124 03-26-2010 09:23 AM
Gas Mileage question: V6 vs V8 MyCamaro5 5th Gen Camaro SS LS LT General Discussions 1 09-10-2009 01:56 PM
Question for you V6 6-speed manual owners . . MI2010Camaro 5th Gen Camaro SS LS LT General Discussions 24 09-02-2009 07:44 PM
94 V6 A/C Question Bryan2230 4th Generation Camaros 0 07-16-2009 11:54 AM
