Old 04-05-2012, 04:46 PM   #1
formare
The Milano
formare's Avatar
Drives: 2017 Firefly ShipWorks
Injen - older long tube; vacum leak
I have one of the original Injen long tube intakes. I noticed on the drivers side PCV hose connection to the Injen tube oil leaking from the connection point many many months ago. I cleaned and moved on.
It dawned on me - "hey me", "yes" I said. That could be a point for a vacum leak. Soooo, i take some of gasket maker left over from the black-ice-olator install and seal up that connection point really well.
The car runs much much better. I mean huge noticable difference better.
If you have an injen - seal that point ASAP...
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Old 04-05-2012, 05:03 PM   #2
TheBlack-CyberGray-Pearl
TheBlack-CyberGray-Pearl's Avatar
Drives: 2011 Cyber Gray Camaro
thanks for the tip!
BBk LT Headers/ Injen LT CAI/ MRT v2/ RX Catch Can/ Black Ice Insulator/ Trifecta Tune/
TheBlack-CyberGray-Pearl is offline   Reply With Quote
Old 04-08-2012, 08:45 PM   #3
hapisok
crazier than a coconut
hapisok's Avatar
Drives: 2010 2SS/RS LS3
nice...i just did this today after reading this. i too have been battling this dilemma. tried other size hose...didn't fit, heat shrink didn't work...it also expands when it gets hot. RTV sealed it up quite nicely. thanks for sharing formare
hapisok is offline   Reply With Quote
Old 04-09-2012, 12:26 AM   #4
VEESIKS
formerly 2011Camaro
Drives: 2011 Camaro LS IBM M6
Never thought of this, definitely going to do this!
Born on the Island and raised in the sand.
Semper Fidelis
VEESIKS is offline   Reply With Quote
Old 04-09-2012, 12:32 AM   #5
lakers171
SoCal MAYHEM
lakers171's Avatar
Drives: 2010 2LT/RS IBM
Can you post a picture of where the leak could be so I can check this in the morning.
lakers171 is offline   Reply With Quote
Old 04-09-2012, 12:50 AM   #6
VEESIKS
formerly 2011Camaro
Do hey have a revised version now or is it still the same?
Semper Fidelis
Old 04-09-2012, 05:39 AM   #7
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
I believe he means this spot.
I plugged mine with a rubber stopper the day I added my RX oil catch can and breather.
Old 04-09-2012, 08:11 AM   #8
hapisok
hapisok's Avatar
yup...thats the spot.
Old 04-09-2012, 08:31 AM   #9
h2oplay
Winners find a way
h2oplay's Avatar
Drives: 2010 2LT/RS M6
formare, did you have any symptoms to lead you to this? Besides an oil leak some time ago?
h2oplay is offline   Reply With Quote
Old 04-09-2012, 08:43 AM   #10
formare
The Milano
formare's Avatar
I was chasing down a phantom fuel trim issue. Or at least what I thought was an issue. My left and right side banks appeared to be competing with each other. My trims were within the +- 5 range on one side but near 0 on the other.
I was looking around for leaks on the vacuum side, my car is factory on the manifolds and cats so figured it must be vacuum. This point was the only spot left.
I sealed up and the results were very very apparent.
Old 04-09-2012, 08:51 AM   #11
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM
I always wondered what to do with that build up.....I have a catch can but no the breather cap, so I still have that vacuum hose plugged in, but the build up is nuts. I will have to do this for sure, thanks for the tip!
Formerly owner of:
2007 Acura TSX
1992 Oldsmobile Achieva V6
1992 Mercury Sable
Blade is offline   Reply With Quote
Old 04-09-2012, 01:50 PM   #12
VEESIKS
formerly 2011Camaro
Is that part of adding the catch can and breather is gettinr rid of that line or is that just something extra you did?
Semper Fidelis
Old 04-09-2012, 06:07 PM   #13
rtcat600man
It is part of the removal procedure when adding the breather. I removed that whole line and plugged both ends with rubber stops.
Old 04-09-2012, 07:48 PM   #14
VEESIKS
formerly 2011Camaro
Good to know. Where did you get your stops from? The catch can and breather are my next additions.
Semper Fidelis
OK...I'm starting a better V6 exhaust examples thread!! KMPrenger Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 611 07-01-2020 08:49 AM
ARH - American Racing 304SS Long Tube Headers | Limited Time MASSIVE SALE! AutoAgenda V8 Bolt-Ons & Tunes 416 06-09-2013 05:08 PM
Injen tube clearance E.T. Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 26 09-02-2011 07:40 PM
long tube headers longbeachss2010 USA - California 35 07-02-2010 10:02 AM
Smokin Deal on JBA 2010 Camaro SS Long Tube Headers Jeff@HHP V8 Bolt-Ons & Tunes 0 01-18-2010 08:54 PM
