Old 12-21-2013, 09:50 PM   #169
ss/rs-matt
Drives: 2015 ZL1
Thumbs up
Originally Posted by 14pilot View Post
You'd be helping out more if you edited your post #1 and put this same update at the top of it. Most, many, almost all reading this thread are likely to miss this little tidbit you just posted.
Done.
"Want to know whats cooler than your murdered out Honda Civic? ...Any Audi." Daniel Tosh
ss/rs-matt is offline   Reply With Quote
Old 12-21-2013, 10:19 PM   #170
14pilot
Original Bumblebee Owner
14pilot's Avatar
Drives: 265hp ZX-14, 500hp Silverado, V-ROD
Originally Posted by ss/rs-matt View Post
Done.
#5 - 2010 2SS/RS MN6 ABM #142-Silver Rallys-GFX / Med Titanium
My previous Camaros:
#4 - 1994 Z/28 6M Black over Arctic White / Graphite-Red Inserts - traded
#3 - 1981 Z/28 Bright Blue Metallic / Black - sold
#2 - 1970.5 RS Mulsanne Blue / Blue - endo crashed it and parted it out
#1 - 1967 RS Butternut Yellow w/ Black Bumblebee Stripe-RPO D91 / Parchment-Black - sold
14pilot is offline   Reply With Quote
Old 02-12-2014, 06:56 PM   #171
OKCwhiteKnight
OKCwhiteKnight's Avatar
Drives: 2010 2LT RS Camaro 2015 Colorado
Any more update's on these?
OKCwhiteKnight is offline   Reply With Quote
Old 02-13-2014, 11:20 AM   #172
Jerry7297
Jerry7297's Avatar
Drives: 2018 2SS/ 1LE
Like mine so far. But they have only been on a couple of months and I dont always DD. But at AutoX I really liked them.
Jerry7297 is offline   Reply With Quote
Old 04-06-2014, 03:09 PM   #173
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
In the middle of this install myself, both fronts are on but I've noticed that now my endlinks are a good 3in below the hole on the coilover where I fasten them to. Did I do something wrong?
kjkjr27 is offline   Reply With Quote
Old 04-06-2014, 03:32 PM   #174
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Nvm got it
Old 02-19-2015, 04:36 PM   #175
ITZ SSIK
marini85
ITZ SSIK's Avatar
Drives: 2011 Camaro 2SS RS
This is something I like to do when jacking up this car, it distributes the load a little and keeps the jack form bending stuff.
With my 1" drop springs I was at 28 3\4" in the front and 29 1\4" in the rear, I wanted another inch front and rear.
Before removing the front struts I marked this just to use as a reference, Ill still need and alignment but this will get me in the ballpark.
Once you get the strut off you'll need to remove the stock upper bushing. You need a spring compressor, a torx t-50 bit and a 15\16".
If you have '10 or newer you'll have to remove the foam insulator so the spring adapter will fit properly.
It should look like this when your done.
Now i played with the spring preload a little, basically what I did was set the the spring adjuster nut so that it just touched the spring right before compressing it. Then go about 5mm past that, which in my case set the spring at about 177mm.
Once the spring preload is set then you can set your ride height. This is were the experimenting comes in as it is up to you to decide what you like. I ended up with 5mm here, which gave me a 2" drop over stock in front.
Tighten everything up and reinstall.
Sorry to bring up an old thread, but your install post is proving very helpful for many!
Anyway, I'm looking to achieve a similar drop to what you did here, but was a little confused by the spacing between the collars. You indicated 5mm but the dial caliper was displaying 20mm. My overall goal is to be around 1.25"-1.5" when all is said and done. Thanks.
ITZ SSIK is offline   Reply With Quote
Old 04-14-2015, 04:33 PM   #176
pbclax1
Drives: Car
Resurrecting an old thread but, any updates on these? Some places buying these vs the BC coilovers are almost a $100 difference...
pbclax1 is offline   Reply With Quote
Old 04-17-2015, 10:40 PM   #177
Jerry7297
Jerry7297's Avatar
I have had mine for a little over a year and love them over stock. But for 100 I would go with the BCs. I got mine a couple of dollars cheaper BNIB from a member or I was going to go with BC.
Old 04-22-2015, 12:24 AM   #178
707 SS
707 SS's Avatar
Drives: 2010 2SS
MEGAN COILOVERS
MY MEGAN SPEC RS COILOVERS ARE AWESOME full adjustability and I love the low stance
707 SS is offline   Reply With Quote
Old 05-06-2015, 09:51 AM   #179
pbclax1
Drives: Car
Are you supposed to remove the foam insulators for BC coilovers as well? According to their instructions you keep it??
