09-20-2012, 08:35 PM | #1 |
Drives: 2015 ZO6 3LZ Stage 2 A8 Join Date: Nov 2010
New master cylinder installed & Shifter
I did all this yesterday... Must say that after driving my car today... It is a 100% improvement. The master cylinder took care of my clutch sticking to the floor and my 1st gear to 2nd gear grinds at high rpm's. The pedal felt so much better, I removed lingenfelters return spring kit....
Took out my POS Barton's shifter and installed MGW's shifter... This things feels great... No more rattles, no more in gear slop, side to side is nice and tight.... 2nd gear to 3rd gear shifts are very very easy.. Can't wait to get to the track and try this baby out! This has been 2 of the best mods I've done! Last edited by kevin1106; 09-20-2012 at 09:31 PM. |
09-20-2012, 08:51 PM | #2 | |
Drives: Black 2011 2SS/RS M6 Vert Join Date: Apr 2011
Great to hear! I am doing these same changes next week. You do mean clutch master cylinder and shifter though. The slave cylinder is actually the hydraulic version of a clutch throw out bearing. Very good to know that it worked out well for you. I take it you have not gone with a separate fluid reservoir yet like many here have done? Thanks.
2011 Black 2SSRS M6 Vert, Nitto Invos on HRE P40s (20X11 rear, 20X9 front), lowered 1" on Pfadt coilovers, Eibach sway bars, American Racing frame brace, Brembo big brakes (16" front, 15" rear), ZR1 dual disc clutch, MGW Shifter, 3.91 gears with Eaton Truetrac and LPW cover, DSS 1000HP axles, DSS 3.5" aluminum drive shaft, Magnacharger with RDS Stage II and 2.8" pulley, Lingenfelter GT9 Cam, GM CNC ported heads, American Racing LT headers with high flow cats, custom 3" exhaust with Magnaflow mufflers and resonator (630 RWHP).
09-20-2012, 09:29 PM | #3 | |
09-20-2012, 09:39 PM | #4 |
Chevy's "Rumble" Best!
Drives: 2015 ZL1 6 speed Join Date: Feb 2011
Nice job! I'm glad to hear you got it going and it worked out.
09-20-2012, 10:19 PM | #5 |
09-21-2012, 07:23 AM | #6 |
LOL yeah it can be a pita.
09-21-2012, 07:32 PM | #7 |
220/221 whatever it takes
Drives: See sig.... Join Date: Jun 2010
What is the bracket I circled in red used for? I just bought a used MGW off a member on here and my shifter has straight arms for the front brackets and came with no instructions. I used their YouTube video to do the install and it made no mention of that bracket???
Brent
2022 BMW X5 M50i 2022 Ram TRX 2021 GT500 CFHP 2016 Challenger Hellcat A8 1058whp/898wtq 1970 Chevelle SS396 4spd |
09-21-2012, 07:40 PM | #8 | |
The piece you circled is also a new added piece... It is used to secure the top rubber boot... You put this in the place where the 2 bolts would go...where you probably used dynamat. |
09-21-2012, 07:42 PM | #9 |
Oh...ok, that makes sense. I had no idea what version mine was, but it shifts fine and I was hoping I didn't leave something out that was necessary. Thanks!
P.S. Congrats on the install. I need to do the IDEALG mod next and your post confirms this.
Brent
09-21-2012, 07:47 PM | #10 |
No problem. You definitely want to do the master cylinder... I was skeptical at first, but glad I did it now. You just have to bleed the crap out of you clutch when you done.... Install was pretty simple... I think it took me an hour from start to finish....
09-21-2012, 07:51 PM | #11 |
Cool...good to know. I wondered how painful it was to install. I may have to order sooner rather than later.
Brent
09-21-2012, 08:07 PM | #12 | |
Being able to work under the dash in a tight spot.... Hard a crap to use both hands Bleeding the clutch Getting the lines off the cylinder under the hood...tight spot Be sure when you remove the metal line, that the rubber washer stays on the end... When putting the new cylinder in, a piece of wire works great to hold the round spacer in place until you the bolt started through the hole If I was to do this again, I could probably do it in 15-20 minutes. |
09-22-2012, 06:47 PM | #13 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2009
Install complete... Full test tomorrow
Just got done installing IdealG clutch master. Was straight forward, not difficult. Just got done bleeding. Can't test now... is raining (have drag radials and no wipers).
I used a hand vacuum pump to bleed system thru the reservoir. A brass vacuum fitting was attached to a GM reservoir cap I had laying around. Pulled 10psi vacuum while the pedal was pumped similar to Jerry's video. Clutch feel is firm, I did start car and back out and pull back in. Only thing I did that I probably didn't have to do was prime the master, then plug up the inlet/outlet ports with snug fitting rubber stopper plugs before the install. (This is how master was primed: Placed rubber tubing into full brake fluid bottle and attached other end to the master inlet port... another piece of tubing attached to outlet port with the other end of tubing going to an empty container. Pumped 5 times to get rid of all air, then inlet &outlet was capped right away. After that it was installed). Will get into some boost tomorrow to test. Btw- I'm hoping to take off the LPE return spring just like Kevin did... we shall see... |
09-22-2012, 08:49 PM | #14 |
Cool man, let us know how things work out for you.
