Old 01-07-2013, 01:44 PM   #1
Garret
Garret's Avatar
Drives: 2013 2SS/RS Victory Red
Check engine light
Will CAI intake and ported throttle body make the light go off?
Garret is offline   Reply With Quote
Old 01-07-2013, 01:49 PM   #2
Camaro1002
Camaro1002's Avatar
Drives: Yellow Camaro 2LT RS
CAI didn't throw that code for me. But the ported throttle body did but I also install a ICE-olator the same day I installed the throttle body and a CEL turned on. But it tuned itself out after like 3 hrs and it's fine now and the response is great!!! I'll love them both bro
Camaro1002 is offline   Reply With Quote
Old 01-07-2013, 01:51 PM   #3
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Not usually, does it happen to be a K&N CAI?
FSP tuned: 377/389
Old 01-07-2013, 02:03 PM   #4
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Neither one should throw a code/light...usually...
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 01-07-2013, 02:21 PM   #5
Garret
Garret's Avatar
Just curious cause I'm on 7k miles got the engine light and I did cat back at 200 miles and CAI inc plus tb same time around a month ago
Old 01-07-2013, 03:08 PM   #6
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
get the code checked by your dealer, or at any autozone, oreillys, advanced, etc for free
Old 01-07-2013, 08:48 PM   #7
jdogscam2013
Drives: 2013 2SS Blue Ray
How do dealers react to CAI, headers, and other bolt-ons ? Would like to do some bolt-ons in the spring but don't want to void warranty? Any suggestions would be greatly appreciated!
jdogscam2013 is offline   Reply With Quote
Old 01-07-2013, 09:55 PM   #8
heymatt
heymatt's Avatar
Drives: 2012 IBM 2SS Vert.
Talk to your dealership service writer. Some are more willing to work with you.
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
heymatt is offline   Reply With Quote
Old 01-10-2013, 11:49 PM   #9
2010 Indy Pace Car
NCCOA Ch 1
2010 Indy Pace Car's Avatar
Drives: 2010 Camaro 2SS/RS - Z4Z # 44
The additions shouldn't throw codes. Concur with heymatt, call the dealer. Most MODS do NOT void a warranty unless they can be directly tied as the cause of destruction and usually not a thrown code.
Sounds as if something else may be amiss. But again, use one of the local auto parts stores to run the code down and tell you what it is first so you'll know where to look.
. ADM CAI,-ARH, JARHEADBOB and MAX, LINGEFELTER TB,
SS CEK,
JANNETTY RACING, RPM Motorsports
2010 Indy Pace Car is offline   Reply With Quote
Old 01-11-2013, 12:59 AM   #10
The Blue Angel
The Blue Angel's Avatar
Drives: 2014 BRM 1SS/RS
Might be the 5000 mile service. It is come so you have to take in to the dealer for a check up!!
2014 Blue Ray Metallic 1SS/RS
A Road Warrior
The Blue Angel is offline   Reply With Quote
Old 01-11-2013, 01:03 AM   #11
TLD0520
NM HT5
Drives: 2010 Black Camaro 2SS M6
I had the light come on for my CAI after a while. Sometimes the sensor just gets dirty or goes bad. I took mine out cleaned it off and the light hasn't come back on yet. But I live in a desert so my filter and sensor need cleaned often.
TLD0520 is offline   Reply With Quote
Old 01-11-2013, 05:32 AM   #12
nyrfan
Let's go Rangers!
nyrfan's Avatar
Huh?
Felix - Sent from my 2SS/RS
FSP tuned: 377/389
