#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
AWE Tuning
Old 07-28-2018, 08:03 PM   #1
Tha_Infamous_E
Drives: 2017 Camaro SS
Directional/Adaptive Headlights
Is there any such aftermarket product for the Camaro SS headlights making them directional/adaptive for turns and what-not? Makes it awfully hard to see in the dark when taking turns unless I'm high-beaming the living shit out of everyone.
Tha_Infamous_E is offline   Reply With Quote
Old 09-19-2018, 01:29 AM   #2
Tha_Infamous_E
Bump... any?
Old 09-19-2018, 02:14 AM   #3
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
No
ninetres is offline   Reply With Quote
Old 09-19-2018, 02:20 AM   #4
MarkC
MarkC's Avatar
Drives: 2018 HBM 2SS/1LE
You can pretty easily adjust the aim point up with a long phillips (or small flathead) screwdriver. Just make sure the beam cutoff doesn't go higher than horizontal or you'll be blinding oncoming cars.
MarkC is offline   Reply With Quote
Old 09-19-2018, 06:22 AM   #5
chutoyy
knows nothing...
Drives: 2SS 1LE
You can custom build a servo motor into each headlight w/ a microprocessor w/ an input from the steering angle sensor that rotates the adjustment screw left and right... Probably not worth it.
'18 6MT 2SS 1LE G7Q
chutoyy is offline   Reply With Quote
Old 09-19-2018, 01:07 PM   #6
Tha_Infamous_E
Damn, one of the most useful mods to a car and they don't have anything like it on the market.
Old 09-19-2018, 01:51 PM   #7
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
DIY - trigger off turn signal, tuck light into wheel well.
ing for grip.
Are you in the NY/NJ/PA/CT region? Join us for autox fun at MetLife Stadium. HUGE lots, tons of runs.
http://www.motorsportsne.com/
Vtor_ZL1 is offline   Reply With Quote
Old 09-21-2018, 02:20 AM   #8
Tha_Infamous_E
Not quite sure what you mean... any guide around here you can reference to?
Old 10-10-2018, 11:34 AM   #9
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
You can thank the big 3, back in 1948 they helped kill the Tucker, it was years a head of its time, 3 headlights and the center one moved withe you in a turn, dont know of a single car to this day that does that, do you.
Old 10-10-2018, 11:46 AM   #10
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Cadilacs had side lights that turn on depending on steering input. My '13 focus had same thing, was very handy for turning into dark driveway.. where you could actually see where light was cast. Nose / turrent view out camaro would probably negate that benefit.. front end just floats in vast area of poor visibility. Too many compromises of utility vs design.
ing for grip.
Old 10-10-2018, 11:52 AM   #11
rspitler
rspitler's Avatar
Drives: 2017 SS Convertible
Had a '13 ATS with headlights that turned
rspitler is offline   Reply With Quote
Old 10-11-2018, 11:45 AM   #12
MGD
MGD's Avatar
Drives: 16 Camaro SS
Tones of them out there.
https://www.autobytel.com/car-buying...lights-131125/
Interior: Adrenaline Red. SS/2SS, M6, NPP, Sun Roof, 8" Nav. Black 5 Spoke Wheels.
MGD is offline   Reply With Quote
Old 10-21-2018, 03:32 PM   #13
Tha_Infamous_E
Uhh... tons of them do it nowadays. Seen them since 5 years ago on Benz and Cadillacs and other models and none of those cars need it more than our performance cars do, since you know... we're the ones actually pushing it to the edge on turns and shit, not the plush cars that take shit at speed limit.
Old 10-21-2018, 05:43 PM   #14
JaxChris
Drives: '16 2SS GD1 MX0 NPP F55 IO6
BMW Adaptive Lighting
Mercedes Intelligent Multi-beam Light System
Audi Matrix-beam LED Lighting
BMW rotates the light assemblies inside the housing based on steering input, this is a replacement of the old cornering light technology which used spotting lights on a 15* degree.
Mercedes & Audi use very complicated systems. Mercedes has multiple small light modules (but don't look bug eyed like Acura) which will activate wider angles with steering and forward road sensor input. Audi has multiple fixed headlights with high-beam intensity at all times, it uses the forward sensors to detect oncoming traffic and disables slices of the light picture to avoid blinding the other vehicle.
I think the BMW approach is the simplest and safest for everyone on the road. It doesn't use full time high beams, doesn't use multiple modules, and could also be improved with a floating auto-level feature inside the housing which would prevent them from blinding people on incline changes or bumps in the road.
JaxChris is offline   Reply With Quote
