09-19-2019, 01:49 PM | #1 |
Drives: 64vette,2010 2SS,2013 Zl1 Join Date: Mar 2013
front camera
I installed a camera in front of my 2019 ZL1 but I can't figure how to get the wires for the display from the engine compartment to the front seat, anybody done that already.
09-19-2019, 02:07 PM | #2 |
Drives: 2018 Camaro ZL1 Join Date: Feb 2011
grommet
There is a small grommet on the part of the door jam where the hinges bolt. I used a small exacto-knife to create a small hole and fed the wires through inside the cabin. Then sealed it up with some 3m strip caulk. No water leaks yet!!
09-19-2019, 02:22 PM | #3 |
Drives: 18 ZL1 A10 Join Date: Nov 2008
behind the master cylinder there is a big harness and grommet. slice grommet.
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS |
09-19-2019, 02:50 PM | #4 |
Who Needs to KNOW?
Drives: 18 ZLE Join Date: May 2018
If not too many wires or thin, use hood release grommet hole - try to avoid cutting grommets - that's how you get water / moisture in the car in places not designed for it.
ing for grip.
Are you in the NY/NJ/PA/CT region? Join us for autox fun at MetLife Stadium. HUGE lots, tons of runs. http://www.motorsportsne.com/ |
09-19-2019, 07:54 PM | #5 |
TBC
Drives: 2017 Fifty 2ss Join Date: Dec 2012
Can u add one to a 18?
2017 Fifty A8, MRC, NPP, NAV, LUM, BLK BOWTIE
09-19-2019, 08:06 PM | #6 |
Who Needs to KNOW?
5th gen DIY has a kit based on hardware from corvette IIRC.
ing for grip.
09-19-2019, 08:36 PM | #7 |
2018 Garnet Red ZL1 conve
Drives: 2013 & 2018 ZL1 vert Join Date: May 2009
I have the Gen5DIY.com front camera kit. Their web page has install videos. Love it!
Build Thread: 2018 ZL1 Vert Purchased (Overpar73)
09-21-2019, 10:10 AM | #8 |
front camera
I had a 2013 zl1 and installed a front camera which displayed in the that cost me about $15.all the pictures and how to do the work are somewhere in 2013 or 14 but I had the shop manuals. GM has not release the 2019 yet and don't know if the plan to so until I can get wiring info, I have a 4" display infront of the transmission stick and that works very good and cost $25. Anybody who has the wiring info, that would be verymuck appreciated
