12-15-2019, 09:32 PM | #1 |
Drives: 2017 ZL1 Join Date: Jun 2018
Open trailer questions
I’m searching for a open trailer. Preferably aluminum that I can load my Zl1 on without having to stack wood or any type of blocking. Anyone have suggestions on what brands to look at. Length ramp length. Just want a simple process
Kooks full exhaust, Roto Fab, Whipple,Williams 103, Fore innovation, JRE cam and tuning
12-15-2019, 10:20 PM | #2 |
2018 Garnet Red ZL1 conve
Drives: 2013 & 2018 ZL1 vert Join Date: May 2009
Open trailer
I have a Aluma trailer and love it! The fenders are removable so the door opens right over the tire when getting out. The loading ramps slide out the back and are stowed underneath the trailer. As you can see it has the protection for the front and also air compressor/winch combo. Good luck.
Build Thread: 2018 ZL1 Vert Purchased (Overpar73)
12-15-2019, 10:36 PM | #3 |
How long is the trailer? Are the ramps 8’? Do you have to use anything to keep the splitter from hitting? Iv rented a couple and did. I’m trying to avoid that.
12-15-2019, 11:02 PM | #4 |
Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
IG: 2fast2nick
-- Current -- 2012 Porsche Turbo S - PDK - Basalt Black Metallic -- Past -- 2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101 2015 Mustang GT PP - Whipple Supercharger |
12-16-2019, 11:49 AM | #5 |
Drives: 2018 ZL1/1LE Red Join Date: Oct 2013
I have an Aluma8220 which tilts (love it!) but still have to place some very small rubber mats before the trailer to 100% clear, getting my tires ~1.5" higher. The Futura is probably the only one out there as a flat drive-on, but, much more costly. (I bought a TractorSupply stall mat which is a dense rubber and about 3.4" thick. Cut it into 1' squares for many uses, including my "lego style" mini ramp use)
BobR
2018 ZL1 1LE (Red) - New Dec 2017 2015 ViperGT (Gunmetal w/Red stripes) 2013 ZR1 Anniversary 2014 ZL1 - BrightYellow, 6sp 2011 Porsche GT3RS - White w/red graphics 2009 Porsche C2S 2001 Ferrari 360 |
12-16-2019, 11:55 AM | #6 |
Drives: 2018 ZL1 1LE Join Date: Aug 2017
I use a Maxey Drop-n-Load .
Works really well |
12-16-2019, 02:12 PM | #7 |
Drives: 2017 SS 1LE Join Date: Mar 2017
+1 futura. I love mine
12-16-2019, 02:33 PM | #8 |
Drives: 2022 Lt1 A10 Join Date: Nov 2015
Here is my 20' Sundowner, removable fenders, tows awesome behind my 17 GMC 6.2. Easy to load and tie down, plenty of room up front for another box. The smaller box comes standard and also comes with side mounted spare
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
12-16-2019, 02:46 PM | #9 |
Couple more pics for you. This trailer listed for 7k. Worth every penny and would never pull a steel trailer again. Traded my enclosed trailer back in for this one.
My ramps are 7 feet long, they slide in the rear and easy loading of my lowered Camaro. It also has torsion axle/springs and not leaf so that's how they get it to sit so low.
12-16-2019, 02:53 PM | #10 | |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
12-16-2019, 03:59 PM | #11 | |
12-16-2019, 05:17 PM | #12 |
Yep, my Camaro is 1.5 inches lower then stock. Steel trailers I've had in the past had didn't work for my car and had to use 2x10s to put under the ends of the ramps to make the 6ft steel ramps work. Never again. Low and go for sure. You'll love it if you buy one and those cool vids Sundowner does on the website its very helpful. Its at least 4-5 inches lower then a standard steel trailer. Here is my old steel trailer and it was a pretty nice one but you can see the height difference.
12-16-2019, 05:26 PM | #13 |
Drives: ZL1 Join Date: May 2018
sundowner has about the nicest trailer you can buy. I have had Aluma, Featherlite, Sundowner etc. The Sundowner towed the nicest etc. Just make sure you get one with 8' ramps as some come with 6'. I bought the sundowner with front storage. Best trailer Ive ever owned.
12-16-2019, 05:33 PM | #14 |
Here was mine. Cant go wrong with this trailer.
