Old 06-08-2020, 01:21 PM   #1
Cornflakes'Camaro
Counting down the days...
Cornflakes'Camaro's Avatar
Drives: Black 2011 2SS/RS
15" conversion complete...have slight rubbing on wheels and tires
2011 Camaro SS, lowered 1.4" w/ carlyle racing 15" kit installed. The lower control arms have a section removed for the lowered car. Tires/wheels are 15" Forgestar D5 beadlocks with 275/60r15 MT Radial Pros. The car hasn't had the camber readjusted since install, and has a slightly positive camber stance.
On the driver's side and the passengers side, the inner wall of the tire is rubbing the lower portion of the LCA (see pics 1 and 2). The wheel itself is barely rubbing a portion of the LCA as well (picture 3).
My question:
Will a simple camber alignment erase the issues, or is a wheel spacer needed for this setup? If the latter, what thickness wheel spacer? Thanks!
Cornflakes'Camaro is offline   Reply With Quote
Old 06-09-2020, 03:28 PM   #2
bayarea408
bayarea408's Avatar
Drives: T
the carlyle's kit is to be used with a coil over setup for adjustments. 15's are a tight fit. seems all 15" kits rub with just lowering springs.
bayarea408 is offline   Reply With Quote
Old 06-09-2020, 04:13 PM   #3
Cornflakes'Camaro
Yea I'm figuring that out. I wish there was more research on the subject. I have some H&R 20mm wheel spacers on the way to help push the wheel out
Old 06-24-2020, 02:07 AM   #4
LHRxDeadx
LHRxDeadx's Avatar
Drives: 2013 Camaro 2SS Inferno Orange
You need to go back to stock height. And get a really good alignment
LHRxDeadx is offline   Reply With Quote
Old 07-27-2020, 07:33 PM   #5
Cornflakes'Camaro
Wheel spacers fixed it.
Tick Performance Custom Cam w/ support mods/BBK LT Headers w/ midpipes/Straight Exhaust/Airaid Cold Air Intake/ZL1 Driveshaft/ZL1 Differential/Hendrix Engineering Offset Bushings/ZL1 Axles/BMR Rear Subframe Bushings/BMR Toe Rods/Carlyle Racing 15" Conversion/Jannetty Winsheild Bottle Scoop/Forgestar 15x10 Beadlocks wrapped in Mickey Thompson Radial Pros
Old 07-30-2020, 05:06 PM   #6
bayarea408
bayarea408's Avatar
Drives: T
so you kept it lowered and used a spacer to make it fit?
Have you launched this setup on prep?
Old 07-31-2020, 09:22 AM   #7
Cornflakes'Camaro
Not on prep. I have spoken to acouple others that have. They have had no issue. What are you thinking will happen?
