07-19-2012, 10:27 AM | #1 | |
Drives: 2010 Mazdaspeed 3 Join Date: Mar 2012
Seal your glass for up to 30k miles with Gtechniq G1!
Coat your glass with extreme protection that lasts for up to 30,000 miles. GTechniq G1 Clear Vision Smart Glass Review - YouTube Gtechniq G1 Clear Vision Smart Glass offers the following benefits:
This glass coating should not be confused with traditional rain repellents. It is scratch resistant and resists premature wear do to wiper blade use; not that you will be using your wipers very much after application. Gtechniq has tested G1 for up to 30,000 miles of use. G1 Clear Vision Smart Glass forms a submicron thick quartz-based coating that chemically bonds to your glass. This coating fills in the imperfections on the glass, increasing the surface tension and causing water to form in tiny sphere-like beads that run from the surface. To apply G1 requires a little prep work for best result. For best results you will need:
Gtechniq G1 is a coating so it needs to be applied to perfectly clean glass that is free of splatter, road film, grease, or wax. Instead of hoping that your window cleaner leaves the glass perfectly clean, Gtechniq recommends using G4 Glass Nano Polish to microscopically polish the surface and leave your glass surgically clean. Gtechniq G4 Glass Nano Polish G4 Glass Nano Polish combines micro-fine abrasives with citric acid to deep clean your glass, removing contamination and restoring clarity. It can be used with a Random Orbital DA polisher on low speed or by hand. I elected to use it by hand using a Wolfgang German Polish N' Wax Applicator. The orange foam side provides a little extra polishing action while the soft black makes handing easy. Glass Nano Polish has a thin consistency. Two quarter sized drops will easily polish half of most standard sized windows. Apply to the glass using firm pressure. Work in a cross-hatch (back and forth, up and down) pattern or in tiny circles. Continue working G4 until only a light film is visible and then remove with a microfiber towel. Application Tip: Work Gtechniq G4 Glass Nano Polish until it is almost clear but remove it while it is still wet for the ultimate ease-of-use. The diagram below shows how G4 will "clear up" or become opaque as it is worked against the glass. Over working the product and allowing it to dry will make removal more difficult. Gtechniq G1 Clear Vision Smart Glass With all of the glass polished and cleaned (including the side and rear) it is ready to accept the glass coating. G1 Clear Vision Smart Glass come packaged with several applicators and G2 Residue Remover. For your windshield Gtechniq recommends applying 3 coats, each on top of the previous, approximately 5 minutes apart. For the side and rear glass one coat will be sufficient. We recommend wearing Nitrile Gloves when applying any type of permanent or semi-permanent surface coating. Apply enough G1 to the applicator to dampen it. Apply to the glass using overlapping circles on in a cross-hatch pattern to ensure even coverage. After one coat. Apply second and third coats to the windshield on top of the previous coats. You should have a uniform film with even coverage. After 3 coats. G1 Clear Vision Smart Glass can be a little stubborn to remove. Dampen the supplied applicator wit G2 Remover and work a second at a time. Wipe away residue immediately with a soft, plush microfiber towel. Repeat until all residue and streaks are removed. |
07-19-2012, 11:15 AM | #2 |
Fedex says tomorrow is the day! Looking forward to it.
[B]
07-19-2012, 01:45 PM | #3 |
07-19-2012, 06:03 PM | #4 |
Drives: 2014 Ford Focus ST Join Date: Jun 2009
This is one on my wish list to get very soon.
07-20-2012, 09:40 PM | #5 |
Switchin' n Twitchin'
Drives: 2011 Camaro Join Date: Nov 2010
I am not childish, you're just being a poopy head!
07-21-2012, 03:44 PM | #6 |
Sorry guys, spent the whole day doing another car. Too tired to do anything with mine today. Hopefully tomorrow I'll get around to washing and using this glass coating.
Todd, do you have any specific recommendations for prepping the glass? Or just clay and apply? --When was the last time you read the Constitution?--
[B]
07-21-2012, 10:45 PM | #7 |
Drives: 2011 Camaro 2SS/RS Join Date: Dec 2010
Hmmm, I am interested. Tell me does it cause any interior fogging like RainX does?
07-22-2012, 08:36 PM | #8 |
"...a little stubborn to remove." A spinal tumor is stubborn to remove. Saddam was stubborn to remove. G1 is nowhere NEAR that easy to remove, lol. This stuff is a nightmare.
I think they include about 1/2 of the G2 you need (although plenty of G1, I kicked the bottle over and still had enough). The whole time, you're frantically checking the levels and realizing you're not going to make it around the car before the microscopic bottle runs out which is incredibly stressful when you're looking at how much residue is left on the glass. When they say to remove the residue immediately, they mean immediately. They don't mean how fast a human hand can set down the applicator and pick up a towel. By that time, it's dried again. Anyway, I finally think I got it all off, I'm drenched in sweat, and my buffing arm is sore. I sure hope it lasts as long as they say, because I'm in no hurry to do this again. If it's as good as they say it is, then all this stress will be worth it. I'm not trying to turn anyone away from it, just giving an honest review. Like I said, if it lasts as long as it's supposed to, then it'll be worth it. Just be prepared for a bit of an adventure.
[B]
07-22-2012, 11:30 PM | #9 | |
07-23-2012, 08:58 AM | #10 | |
07-23-2012, 10:54 AM | #11 |
I'm looking forward to it. Noticed a few spots in the sunlight today. Hopefully I can buff them off.
[B]
07-24-2012, 09:06 AM | #12 |
07-24-2012, 10:44 AM | #13 |
Ipa won't remove the coating?
[B]
07-24-2012, 02:57 PM | #14 |
No it won't. G2 Glass Coating Residue Remover is some type of alcohol base. Many of the UK guys recommend using IPA instead of G2. At this point the only thing that is going to remove your coating would be an abrasive polish.
