08-25-2023, 05:29 PM | #1 |
Drives: 2010 Camaro ss A6 "Chief" Join Date: Dec 2020
300+ Oil Temps
Hi yall, recently got my Camaro back form the tuner after having the transmission retuned. On my way rom the coolant temperature got all the way up to 252*, my car usually runs hot (220-230) normally down here in south houston.
What i didnt expect was 1. the coolant to get that high. 2. the oil temps to steadily climb up from 210-220 all the way to over 300. It maxed out my center console guages. Ive had probelms with the driver side cooling fan not kicking on in the past, and a simple relay fan fixed that, i did notice that the fan was running, but very slow. My tuner advised me to take out the thermostat and take it for a drive to see if the thermostat was stuck, a short drive later the coolant temps fluctuated from 215-230, and oil temps consistantly climbed from 180-275 before i shut the car down. didnt matter if i was cruising, doing a pull, or stopped at a light. the oil tempurature would not stop climbing. Good news is that the oil pressure sstayed at a good 32 at idle even at 300+ temps lol, got all tehg way up to 65 cruising Im at a loss on what to do next. any help would be so very greatly appreciated
TSP stage 2 cam | aFe cai | Speed Engineering Long tube 1 7/8 catless headers | Self Ported TB | Circle d 245mm 4400 stall | ZL1 NPP Cat-back exhaust | 3.91 gears | Full BMR suspension/bushings |VMS drag pack 17x10, 17x4| Granatelli Motorsports pro stock spoiler| Heritage Grille | Zl1 Addons front bumper conversion kit | Whole lotta weight reduction
08-26-2023, 06:24 AM | #2 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
What brand and weight of oil are you using? To me I would check your high speed fan relay. There are two relays if I remember correctly, one is a regular fan relay and the other one is the high speed relay. You can pull the high speed relay and directly connect the two connections that make it work and you should be able and tell a big difference from regular speed and high speed. And you should compare it when the temp is I believe above 230* or so. Another thing you can do is when it's really hot like that while it's running with your ac on the fans should be running at 100%. On another note your "Tuner" should have decreased the temp on % for your fans to come on at 100% at like 210*
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 Last edited by morepowerjoe; 08-27-2023 at 01:12 AM. |
