10-19-2015, 06:27 PM | #1 |
Drives: 2013 Camaro 1LS - Ashen Gray Join Date: Jan 2015
Started IPF install
Started install today.....took a few pics
"WIDOW" Overkill Edition w/Mace Cams,80mm tb,Jacfab spacer/ported intake,Alky Control,ARH off road pipes,SOLO custom system,3.91 gears, MGW,Phantom grilles,ZL1 appearance pkge, 3dCarbon vents, Lingenfelter hood and spoiler, PLX boost/wideband modules/gauge,ZL1 fuel pump,LF3 hpfp,DSS aluminum driveshaft,JPSS sway bars, Z28 replica wheels and CxRacing coilovers..
10-27-2015, 01:44 AM | #2 |
Drives: 2013 VR vert ZL1 Join Date: Aug 2012
Sweet. Subscribed.
And are you using your stock rear end and gear ratio? Sent from my SM-N900P using Tapatalk |
10-27-2015, 04:25 PM | #3 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Nice! Anxiously awaiting my install.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
10-27-2015, 05:45 PM | #4 |
Drives: 2011 RJT 2LT/RS Convertible Join Date: Nov 2009
Here comes a permagrin ! Join the club !
1st IPF Supercharged 2011 2LT/RS RJT Convertible
10-27-2015, 08:04 PM | #5 |
Supercharger and meth install finished up friday..... once again tuning didnt go well.... my installer is unable to crack the lfx Code of tuning....throttle opening percentage issues,etc above 5100rpms.. it seems he is block tuning... im safe to 5000 rpms until I can get it tuned ... Ughh lol... it did manage a 393rwhp and 327tq anyway with throttle only opening 67 percent and going lean up top.....
10-27-2015, 08:06 PM | #6 |
Why not go with the IPF tune?
10-27-2015, 08:17 PM | #7 |
They dont support smaller pulley,cams or methanol.....Phil of Tampa tuning did my cam tune but out of town until next week and poss booked out for 2weeks.....
10-27-2015, 08:24 PM | #8 |
I would strongly consider Will@overkill motorsports of Canada....he did great work on my 3.8 monte ss tune and seems to be making great strides with the 3.6 now... remote tuning,3.5 maf tube and an 80mm throttle body in the works! Just so damn hard to reach him.......
10-27-2015, 08:55 PM | #9 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
Remote tuning something like you have seems really risky in my mind.
I've emailed back and forth with Will several times, he is now carrying my intake spacers for both the Camaro and the Impala. Seems like a great guy. I've got a trans tune he sent me for my G8 GT I haven't had a chance to try yet. |
10-27-2015, 09:05 PM | #10 |
Hmmm cant seem to get a response.... I relocated the maf/iat sensor in a 3" tube with meth nozzle just before throttle body.... I see he has a 3.5 tube and a 80mm tb thats close to being ready.... maybe you can mention my build to him ...my email is ddjni5@aol.com
