06-25-2014, 05:28 PM | #1 |
Drives: Yellow 2SS camaro Join Date: Mar 2013
L99 resonator design.
Well I recently cut off my resonator because I have been told that it is restrictive . All I can say is it is a straight through design and not restrictive at all . Here are some pictures I took .
06-25-2014, 06:28 PM | #2 |
Lifestyle = Deathstyle
Yep. JRE told me to keep mine. Was upgrading to headers after I had Borla S Axle back installed. Best advice as I read so many people want to quite down their rides after going with X pipes.
11 2SS/RS
06-25-2014, 07:09 PM | #3 |
MY SS is SOLD
Drives: AGM 2012 Camaro 2SS/RS L99 Join Date: Mar 2012
Here is a pic of it cut open.
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
06-25-2014, 07:46 PM | #4 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
I had mine cut out and swapped in an x pipe.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
06-25-2014, 10:03 PM | #5 |
HT5 in the 626
Drives: 2014 Camaro 2SS/RS Join Date: Nov 2013
why quiet your car down?!?!
2014 L99 Camaro 2SS/RS ~ Flowmaster American Thunder Catback ~ Cold Air Inductions CAI ~ VMAX Ported TB ~ ARH Catted LTs ~ Tuned by Ted @ JRE A wise man once said, he who eats crackers in bed get crummy sleep. |
06-25-2014, 10:32 PM | #6 |
Lake Erie Monster
Drives: 02 Hyundai Santa Fe and 13 300 Join Date: Aug 2012
^^2X
Everything I say is to be taken as an opinion and not fact so don't get upset over words that spill out of my head.
GO CAVS! |
06-27-2014, 07:55 AM | #7 |
Drives: 2011 2SS/RS, '22 Silverado Z71 Join Date: Sep 2010
Ahhhhh!!!! Thank you!!!! I have seen this one other time and never thought I would see it again. I knew the pipes were gapped and they didn't have any sound proofing material inside the L99 resonator. Thanks for posting. I had a short discussion with Magnaflow Tech support about what was inside it when deciding on which resonated X-pipe to order.
And I guess I have to admit, after the header install I want to knock down the higher RPM sound just a hair and refine it.
06-27-2014, 08:12 AM | #8 |
Drives: 2010 Camaro 2SS RS Join Date: Nov 2011
I have Doug Thorley Short tubes, solo HFC, along with a solo axle back with the stock resonator, and it was very throaty and would experience alot of vibration on high RPM especially on a downshift when using the paddles
Put on a solo catback which is essentially the same thing except with a resonated X pipe, and it is night and day how much smoother the car feels and sounds. It is a bit quieter at idle though Last edited by BronxxBombers213; 06-27-2014 at 09:35 AM. |
06-27-2014, 09:27 AM | #9 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Guess that'll teach you not to believe everything you read/hear
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
06-27-2014, 10:03 AM | #10 |
Drives: 2013 SS Join Date: May 2013
Weight reduction, thats why.
06-27-2014, 02:34 PM | #11 |
Drives: Cyber Grey 2010 2SS RS Join Date: May 2012
I honestly wish I would of kept mine. I had the issue some people of had with them where the internals came apart and would rattle at certain RPMS. With no warranty it had to go.
2010 2SS/RS
-Headers, catback, Holley Mid-rise and a 150 shot- |
06-29-2014, 09:01 PM | #12 |
I now run my car with solo axle back and second cat delete ,and I keep my stock resonator .It sounds good to me and I get compliment all the time .
06-29-2014, 11:24 PM | #13 |
The biggest problem with the stock setup is in the picture for me
The pipes aren't connected and it creates heat in the car next to my foot if I drive for a long time That's what mods are for so magnaflow X for me For others it works so keep it
K&N TYPHOON http://www.youtube.com/user/Baltimorejohn1
06-29-2014, 11:46 PM | #14 |
WHAT RED LIGHT?!
Drives: 2011 Black Camaro 2SS/RS M6 Join Date: Apr 2011
There is very little restriction if any with the stock cat back. Dyno numbers have proven that. Only worth changing for sound, weight reduction or FI applications.
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
