12-30-2015, 05:14 PM | #1 |
Drives: 04 z06 yellow Join Date: Jan 2008
Got a 2015ss and feels slower than my 2010ss
I still have my 2010 ss, I didn't trade it. Both automatics. The 15 feels definitely slower, it has 1600 miles on it. Is there something in the computer till a certain mileage holding th HP down?
12-30-2015, 05:26 PM | #2 |
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3 Join Date: Jun 2010
What "feels" and doesn't "feel" slower or faster....that's a whole lot of interpretation and guesswork. All you'll get is opinion, nobody can actually answer this.
12-30-2015, 05:45 PM | #3 |
Gold bricks in the trunk of the '15?
Sent from my SM-N900V using Tapatalk
-Cameron Lashley
Albany, GA 2011 Camaro 2LT/RS 3.6L M6 Summit White w/silver rally stripes CAI intake, VTC, VMax PTB, VMax Iceolator, Apex intake scoop, Roto-Fab washer bottle relocate Build Journal: http://www.camaro5.com/forums/showthread.php?t=419992 . |
12-30-2015, 05:47 PM | #4 |
Drives: 2015 summit white 2SS/RS Join Date: Aug 2015
Is there a weight difference? The motor is the same
12-30-2015, 05:55 PM | #5 |
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99 Join Date: Nov 2015
How many miles did it have on it when you picked it up? Mine was a GM Black Friday Event deal, so it had 421 miles on it from being on the lot so long.
Do the fuse pull. I wasn't a believer either at first, but sure as anything the dealer put 87 gas in it. It makes a world of difference. Run the gas almost out of it, fill it up with 93 or 91 and do the fuse pull. Fuse box is on front right side, under the hood. Flip the top of the cover back, pull out the built in fuse puller (gray) on the bottom right corner, pull fuses #5 and #20, take them in the house and put them back in the morning. You WILL be happier!!
PERFORMANCE: ColdAirInductions CAI, ADM Race Scoop, Cordes Performance Racing Ported TB/IM/Custom VVT Cam, WFO Milled Heads, Stainless Power 1 7/8" LT/3" HFCs, JBA 3" Comp. Cat-Back, Taylor 10.4mm Plug Wires, Tim King Performance Stage 3 6L80, Circle D Billet 3600 Stall, Nic D ECM/TCM Tune, - 458rwhp/413rwtq (prior to PIM), Forgestar F14 (F)18" / (R)17" Rims.
SUSPENSION: Z/28 Rear UCA Bushings, Carlyle Racing LCA/TA, BMR Adj. Toe Rods/Xtreme Anti-Roll Bar, Justice Pete Castor Locks/Radius Rod Inserts, Pegasus Billet Rear Cradle Bushings, Mickey Thompson Street SS II 305/45/17 tires. |
12-30-2015, 06:12 PM | #6 |
Drives: 2014 Red Hot LS3 Join Date: Oct 2014
Are they both coupes?
12-30-2015, 06:34 PM | #7 |
both coupes both automatic. The 10 is a 1SS, the 15 a 2SS
12-30-2015, 06:38 PM | #8 |
Drives: 2015 2SS/RS vert, Spring Green Edtn Join Date: Jun 2014
Here's a thread on the fuse pull topic. It has a how-to with lots of pics:
http://www.camaro5.com/forums/showthread.php?t=38964 As for running out the cheap gas, instead of going through a few full tanks of 93 octane, I ran mine to almost empty, then put in about $5.00 worth of 93 and ran it to almost empty again. I did that twice, then filled up with 93. I figured that would wash all the 87 out a lot quicker since it takes me about 3 weeks to go through a full tank (I live super-close to work). You can also just disconnect the battery instead of pulling fuses, but then the infotainment system gets set back to factory default and you have to reset all that.
2015 2SS/RS vert, Spring Edition Green Flash (2015 - present)
2014 1LT vert, Blue Ray Metallic (2014 - 2015) |
12-30-2015, 06:45 PM | #9 | |
Drives: Camaro and Sierra Join Date: Jul 2012
12-30-2015, 10:02 PM | #10 |
Drives: 2015 Camaro Join Date: Dec 2015
Maybe GM secretly went more aggressive in the TQ management control on the '15's.
12-30-2015, 10:12 PM | #11 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
It's probably because the 15 drives much better than the 10, and the speed is less noticeable. I would bet if you were to line the two up, the 15 would be faster.
12-30-2015, 10:49 PM | #12 |
Drives: 2011 1SS/RS LS3 Join Date: Dec 2012
Maybe the 2015 caught a glimpse in a tailor's mirror and the taillights did a number on its ego. Any girl would give up and run slow if someone older than her had a more attractive rear end.
Just Kidding! Wanted to reminisce on some of the late 2013 posts
CAI intake, apex scoop, Vmax ported TB, MGW short throw, BMR 1" springs and sways |
12-30-2015, 10:53 PM | #13 |
Homeless Life Chose Me
Drives: LS3 (sold 4/21) Join Date: Nov 2014
Prob cause it's not fully broken in yet. Only 1,600 miles
Pity a man in familiar places, who yet feels like a stranger.
12-30-2015, 11:12 PM | #14 |
Drives: 2012 1SS M6 IOM Join Date: Dec 2012
They slowed down the 14's and 15's so the Mustang guys can keep up.
Its prob the same. Nothing different.
2012 1SS Camaro LS3 Inferno Orange
Mods: LSA Supercharger, 2.55 Pulley, Custom Boost Cam, ARH LTH 1 7/8, HFC, 3' Magnaflow Exhaust, JLT CAI, Elite CC V2, BO White Stage 2 TB, GM 3.91 Gears, DSS CF Driveshaft, BMR Bushing Kit.... . Tuned by JTM Motorsports 540 Hp 550Tq on 9PSI Axles, Monster Clutch, Hotchkis TVS Track Pack kit.......For 2018. |
