03-29-2010, 12:03 PM | #1 |
Drives: 2006 Lamborghini Gallardo Join Date: Feb 2010
For those of you running quick/fast, axles / ds?
Just want to do a rough poll on who's running what axles and driveshaft combos to hold up to mid 11's and quicker.
Please list LS3/L99, Axles, Driveshaft (if any) and any other driveline mods you've done to withstand the launches. Also, listing 60' would be helpful. Thanks in advance!
2010 Camaro 2SS, 700RWHP, 667RWTQ @ 9psi - 11.03@124 @ 3600 ft. elevation TVS2300, Ported Stock Heads, Ported TB, Comp Cam, RPS Twin Disk, Kooks 2" LT's, Kooks 3" Catback, Dual ZR1 Fuel Pumps, H&R Springs, Barton STS, Hendrix Axles, BMR Trailing Arms, Snow Methanol Kit, Rotofab CAI. 2006 Lamborghini Gallardo, 2006 Cherokee SRT8. 2014 Mercedes CLA (On Order) / CLA Forum |
03-29-2010, 01:16 PM | #2 |
Drives: 2010 2SSRS m6 Join Date: Jul 2009
I am running nittto 305's, richmond 4:10's, and hendrix axles. (300M axles.) i am still on the the stock driveshaft because I have not found one yet. does anyone know who makes them yet. Oh yeah and I am running ~800 RWHP
03-29-2010, 01:28 PM | #3 |
Drives: 2010 Camaro Join Date: Feb 2010
I just ran a 10.99 with a 1.6 60' on M & H dr's and every drivetrain part is stock.
03-29-2010, 05:54 PM | #4 |
Drives: First 9 inch-12 bolt IRS Camaro Join Date: Jun 2009
That is a graet time for sure.Im sure you know your on borrowed time,ive had one lady with a cam only break axles in a six speed,unfortunatly these axles are pretty sad.When your ready let us know,if your at the fest come buy our truck and check them out first hand.
03-29-2010, 05:55 PM | #5 | |
03-30-2010, 11:16 AM | #6 |
03-30-2010, 01:16 PM | #7 |
Just gave you a call and left a VM.
03-30-2010, 10:14 PM | #8 |
VETT 4 5
Drives: Yellow 1SS/RS w/ Clutch Join Date: Nov 2009
Mark_P - what times are you running now ? Do you have times before/after the 4.10 swap ? I've been asking but haven't seen ET changes due to gears alone.
03-31-2010, 09:20 AM | #9 |
sorry I was at the track to get some times before the swap and it started raining. I haven't made a pass since the new motor went in. So I will not have any direct comparisons with and without gears. I wouldn't expect much better times with my car because of the HP its making. On stock cars though I could see a substantail gains as they do not get off the line very good in stock form.
04-01-2010, 08:54 AM | #10 |
04-01-2010, 09:40 AM | #11 |
Drives: 2010 RS/SS2 Join Date: Jul 2009
10.20's on stock axles, 1.5 short times and I've made by far more passes in my car then anyone.
2010 SS/RS SIM
First to run 11's (11.83)on a stock long block. First to run 11's cam only First to run 11's all motor First to run 10's (10.96) and did it with a 100% bonestock long block and a power adder (nitrous) First to run 10's (10.55) on motor in 2010 Camaro First to break into the 5's (5.97) 1/8th mile First to cut a 1.5X sixty foot First to cut a 1.4x sixty foot First to car to cut a 1.3x 60ft |
04-01-2010, 12:01 PM | #12 |
No suspension work? no drivetrain work?
04-01-2010, 01:28 PM | #13 |
Eibach spring kit, that's it. It is a 6 speed manual
2010 SS/RS SIM
04-01-2010, 01:29 PM | #14 |
Very awesome, what are your 60 foots? Any wheel hop?
Similar Threads | ||||
1000 HP SEVERE DUTY AXLES ???? | markssylver | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 34 | 10-24-2011 10:31 PM |
Hot Deal For DSS 2010 Camaro Axles | Paschal Performance | Transmission / Driveline | 3 | 03-04-2010 08:36 PM |
1,000 HP Extreme Duty Rear Axles and CV Joints Package | SpohnPerformance | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 31 | 02-24-2010 10:50 PM |
Gforce Engineering axles and driveshafts coming soon | GFORCE1320 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 13 | 02-13-2010 11:29 AM |
NEW Driveshaft shop High output axles! | IPS Brandon | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 18 | 09-19-2009 02:38 PM |
