07-06-2014, 09:38 AM | #1 |
Drives: 2010 CGM Camaro 2SS/RS Join Date: Jun 2012
Cammed
Hi Guys,
Was wondering if those with cammed Camaros had to do anything before handc(or after) prior to getting it cammed? I was looking to get my SS cammed but I'm a little hesistant. How has it improved performance? Also, do I need to get additional parts? |
07-06-2014, 09:57 AM | #2 |
Drives: 2010 2SS/RS Join Date: Jun 2009
It's great. Picked up7hp and 18 tq.
07-06-2014, 10:23 AM | #3 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Read read read. Hundreds of posts here. There are always extras when you mod. At minimum, a cam will require hardened push rods, valve springs, headers and a tune. And the little extras like oil change and coolant. And, if you have an auto transmission, you'll likely need a torque converter.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
07-06-2014, 01:43 PM | #4 |
Drives: 2011 Inferno Orange metallic 2SS Join Date: Aug 2013
07-06-2014, 03:57 PM | #5 | |
This - I spent 6 months reading and found a ton of new information to consider all the time. The biggest thing is find a quality shop that you will have do the work and tune and figure out what they have experience doing - you don't want to be anyone's guinea pig Sent from my iPad using Tapatalk |
07-06-2014, 07:16 PM | #6 |
WHAT RED LIGHT?!
Drives: 2011 Black Camaro 2SS/RS M6 Join Date: Apr 2011
He is either joking or confused...more likely joking lol
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
07-06-2014, 07:37 PM | #7 |
Drives: 2SS/RS CGM LS3 Join Date: Aug 2009
07-06-2014, 07:48 PM | #8 |
Here is a list of extra parts I got:
Trunion upgrade BTR Chromoly push rods BTR Titanium dual springs, seat, locks, retainers BTR SLR lifters and trays 3 bolt timing gear C5R timing chain LS2 chain tensioner Melling high volume oil pump LS9 head gaskets valley cover w/gasket front timing cover w/gasket Circle D torque converter ADM transmission cooler ARP head bolts, cam bolts, and crank bolts Cam Motion camshaft I think this is my whole list. This is a LS3 conversion too, but as you see its not just pull cam out and put new one in. All in all the parts ran me about $2500+
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs Last edited by rberns; 07-06-2014 at 08:47 PM. |
07-06-2014, 08:56 PM | #9 |
Drives: 2013 AGM 1SS/RS LS3 Join Date: Mar 2011
Berns, why switch to the LS2 chain tensioner, is there that much of a benefit or it is required due to the LS3 conversion?
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts |
07-07-2014, 09:09 AM | #10 |
Geek
The LS3 tensioners have broken a bunch of times. I switched to the LS2 damper as well.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1 x = ~x |
07-07-2014, 09:18 AM | #11 |
07-07-2014, 10:56 AM | #12 |
Maybe you're mistaken, and to clarify 1st dyno was done on a mustang, 2nd was dynojet, here's my before and after numbers. 41/22 sorry was off a number.
https://fbcdn-photos-d-a.akamaihd.ne...70731253_n.jpg Last edited by IOMss11; 07-07-2014 at 11:17 AM. |
07-07-2014, 12:02 PM | #13 |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
Yes lol, lots of parts needed, do some research, call a shop.
But its a great idea, a good cam improves performance across the band, and is a lot of fun to drive/listen to. |
08-07-2014, 02:48 PM | #14 |
Drives: 2011 LS3 Join Date: Jan 2012
I did my cam 2 months ago after a few months of searching I decided to go with the night fury cam from lethal. And the shop I had it installed put on BTR components for everything else valvetrain related. I gained a total of 55rwhp and only 20 tq my final dyno was 455/417 on a ls3.
Stainless Works Headers Vmax TB SLP loudmouth 2 Nightfury Cam Mike Norris CC Tuned by Southwest Speed |
