Old 12-28-2019, 03:15 PM   #1
f5journal
Senior Camaro Fanatic
f5journal's Avatar
Drives: 2011 SS/RS manual - White
2011 SS Front hub help requested
I am needing a front hub for my car. My searching leads me to think that 2011 was a one year only hub, and now I cannot figure out what really fits.
It appears that the SS front hub is different from the rear, but only on 2011.
I have two OEM hubs for the rear GM #22924741 that I got when I changed out the rear diff. Apparently these are correct for the rear, wrong for the front unless it's a V6
Does anyone know exactly what I need? I can enter my car info on GM parts, but when I click on front hub it says, sorry, wrong part for your car
Thanks
Former '68 and '69 Z/28 Owner...........Now sporting around in a 2011 RS/SS with........Kooks LT's and cats, JRE tune, CAI, scoop, ZL1 Bumper conversion, custom ZL-1 grille, halo harness, Painted silver stripes, GM GFX, black painted lower edge of skirts and rear bumper. MGW shifter.....and now a 3.91 1LE diff
f5journal is offline   Reply With Quote
Old 12-28-2019, 08:41 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Try Rock Auto you should be able use the 4415 that’s found in the ZL1/1LE.
Orange Krush II
Old 12-30-2019, 11:31 AM   #3
f5journal
f5journal's Avatar
Thanks
