Old 05-08-2012, 02:19 AM   #1
Leb SS2/RS
Leb SS2/RS's Avatar
Drives: 2011 Camaro SS2/RS
Any suggestion on big brake kits?
hello camaro5 members,
I was looking to change my stock brake pads and rotors to performance spec ones... But I decided to go for a big brake upgrade kit front only, now I know there are a lot of 6 piston big brakes, I wanna know which is the best choice for the money... My budget is around 3000 $ maxx... Cheaper is better but can't mess around with brakes!
Any suggestion, offer , or help appreciated
Leb SS2/RS is offline   Reply With Quote
Old 05-08-2012, 02:51 AM   #2
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
http://www.camaro5.com/forums/showth...ighlight=cts-v
Best bang for the buck if you ask me.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 05-08-2012, 02:59 AM   #3
jasycz28
J.Sick
jasycz28's Avatar
Drives: 2010 Camaro SS
"J.Sick"
2010 Camaro 2SS
jasycz28 is offline   Reply With Quote
Old 05-08-2012, 10:57 AM   #4
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
Have you seen these?
http://www.blu808.com/2010-Camaro-Ba...its_p_327.html
Blu808 is a forum sponsor as well.
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims
pyr0b0y is offline   Reply With Quote
Old 05-08-2012, 11:01 AM   #5
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
I tend to agree with the CTS V upgrade. for the money it is the best bang for the buck upgrade..
Old 05-08-2012, 02:13 PM   #6
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Your OEM Brembo's are performance brakes. Changing the fluid to high temp fluid and switching to stainless steel brake lines will make a good bit of difference. Are you wanting to change for anything specific? Autox, roadcourse, looks?
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-08-2012, 02:19 PM   #7
ModBargains.com
ModBargains.com's Avatar
Drives: Widebody 2013 Mustang GT
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
I'd take a look at StopTech if you're serious about getting some good braking power! StopTech is less expensive than Brembo but it still has the performance behind it to back it up. Just a thought though, you should at least explore the option if you ask me
ModBargains.com is offline   Reply With Quote
Old 05-08-2012, 02:25 PM   #8
Topher3134
Drives: delete me
I think the wilwood setup is the best bang for buck. Its about 2000 and its got aluminum hats and 6 piston calipers. I think blu808 sells them.
http://www.blu808.com/2010-Camaro-Wi...its_p_345.html
Topher3134 is offline   Reply With Quote
Old 05-08-2012, 08:20 PM   #9
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
Anyone used the Wilwood or Baer options?
And I don't understand how anything over $2000 is "best bang for the buck". I've seen the CTS-V fronts listed for $1200. They are bigger, work better than stock, and they are the same weight. And as noted in the link above, they have been used and tested.
JimE is offline   Reply With Quote
Old 05-09-2012, 01:36 AM   #10
Leb SS2/RS
Leb SS2/RS's Avatar
Specifically I need them to be able to stop 850hp my car is currently aroun 625 on a S/C and the OEM brakes are not doing a gr8 job....
But I am in need for a big brake kit because my SS is currently under engine build.. So I need brakes to stop.... So am searching for brakes (best bang for buck)
Old 05-10-2012, 12:14 AM   #11
blk96gt
Drives: 11 SS(sold),96 Mustang,12 Silverado
Unless your driving on a road course and heating your brakes up significantly there is no reason you need a big brake kit. Even on a road course just getting some higher performance pads will tend to solve any fade issues you have.
Your also not going to stop any faster with a BBK either. Your tires are the limiting factor. Your ABS will engage before you reach the limits of your stock brakes.
When people think they are stopping faster with their new brakes with no tire changes all they are feeling is the initial bite. Your stopping distance is the same, it just takes less pedal to do it.
blk96gt is offline   Reply With Quote
Old 05-10-2012, 01:58 PM   #12
Kwik
Drives: car
I went with the Brembo caliper only upgrade and Granatelli slotted and dimpled rotors.
Upgrades to suspension, brakes, motor and appearance. 482.7 RWHP- 434.2 RWT - All motor.
Kwik is offline   Reply With Quote
Old 05-11-2012, 09:08 AM   #13
Doubleblank
Doubleblank's Avatar
Drives: 2010 Camaro SS, 2014 Z28
Here are my StopTech's. The silver calipers look great with the Forgelines. The red or other colors would have clashed big time with the orange paint. 15 inch rotors up front and stayed 14 inch in rear. Barely bedded in but hope to get out to MSR next week or two to finish setting up the entire install which included KW Variant 3's and Pfadt Racing ASB's.
ERL 500 ci Short Block, 2in ARH Headers, TSP LS7 Heads, LSXR/NW 102, Forgeline, MGW Shifter, StopTech BBK, Pfadt C/O's, Pfadt ASB's, etc, PowerFab Dynotune
Doubleblank is offline   Reply With Quote
Old 05-11-2012, 09:31 AM   #14
Leb SS2/RS
Leb SS2/RS's Avatar
Very nice looking setup doubleblank , well done on the caliper color to match ur color scheme... how much did this set up cost you if u dont mind me asking ?
