07-24-2012, 06:18 PM | #1 |
3bood
Drives: Camaro 2010 Join Date: Feb 2012
Turbonetics Turbo Oil Dran INSTALLATION Help
07-24-2012, 07:36 PM | #2 |
Sorry, I am misunderstanding your question, your suppose to drain the oil just enough so when you drill the hole oil will be right below the hole. Then start with a small bit and work up to keep shaving sizes minimal. You can pack the bit with grease also to try to hold the shavings. The instructions are very clear on what to do here. Good luck.
07-24-2012, 08:43 PM | #3 |
Drives: 2011 SS/RS Join Date: Apr 2011
In the instructions they show the fitting on the drivers side corner of the pan (just to the right of your hand). I actually left all the oil in my pan when I drilled my pan, kinda makes a mess but the oil trying to come out of the hole imo helped push the shavings out as you drill. Just find something to plug the hole will you change bits.
07-24-2012, 08:54 PM | #4 |
You need to drill the hole above your normal oil level. The measurement is on the instructions. If you drill below your normal oil level the oil drain will back up and the car will smoke.
Drill the as stated in the instructions 1/8" then your final size with grease. This will have the least amount of aluminum fall in. Try to stop right before you go through and clean off the shavings and re-grease. Then drain your oil. If you want pour oil in after you drain it to flush anymore chips out. By the way.. Do not try and drill higher than the measurement given. You can drill into the windage tray or baffle. I found that out the hard way.
LS3 M6 w/ Turbonetics stage 1 turbo kit
Huron Speed twin 64's waiting to be installed |
07-24-2012, 08:56 PM | #5 | |
Huron Speed twin 64's waiting to be installed Last edited by outlawprostreet; 07-24-2012 at 09:01 PM. Reason: adding to post |
07-24-2012, 09:06 PM | #6 | |
Long story short, I plugged that hole and retapped about 1/2" from main top of pan on the driver side front. Right above his hand in the pic is pretty close. |
07-24-2012, 09:24 PM | #7 |
I hear you. I got lucky and just nipped the bottom of the baffle. It did make it a pita to tap though.
07-24-2012, 09:41 PM | #8 |
It wasn't too bad where I tapped mine. I had to take the sway bar loose an the hot wire to starter. It put the fitting just above baffle. Haven't had any problems since.
08-05-2012, 02:01 PM | #9 |
3bood
Today i start up the car...
the turbo leak oil on the pipes and the car makeing white smoke !! I open the hose on the pan and 3L of oil drop off WHAT I MAST DO ILL ADD SAME PICS |
08-05-2012, 03:08 PM | #10 |
3bood
guys can anyone take a pic for the pan because i dont know where to drill naw
the car seems good when it have 5L of oil .. |
08-05-2012, 03:17 PM | #11 |
Car Lover By Nature
Drives: 2016 Hyper Blue Metallic SS Join Date: Dec 2009
Good Lord. That must suck. I think I'd have to either pull the pan or the entire engine if I had to go that route. The chances of shavings falling inside the pan would make me cringe.
08-05-2012, 03:22 PM | #12 |
Drives: 1991 Camaro Join Date: Apr 2012
Where did you drill for the drain? Like stated above, if your below the oil level it will not drain properly.
2011 SS Twin Turbo
Forged LS9/6L90E Runs 9's |
08-05-2012, 03:23 PM | #13 |
3bood
we clean the pan with oil 7 times and no shavings are inside
the problem is i want to know where i drill exactly the hole on the pan the instructions not clear so ... |
08-05-2012, 04:41 PM | #14 |
3bood
Thread Tools | |
