12-20-2009, 03:45 AM | #1 |
HELP!! Rev limiter kicked in at 4Krpm!
Guys/Girls somethin happened today and I dont know what caused it!
Was launching the car with trac/stab all on launched it at about 2-3k rpm and I think the road was a bit dusty as tires spun a bit more than expected even with traction on. Anyway thats not the point! Traction caused rpm to bog down lower till about 1.5K before properly launching and I was WOT or very close to it, with my eyes on the rpm gague and the rev limiter kicked in at 4K RPM!! It only hit the limiter once then I let go of throttle and got on it again and it continued as normal.... Can someone tell me what happened??? I think this happened before but I wasnt really paying attention to the rpm level so wasnt sure at the time. FYI M6 LS3 ~1200Miles first incedent @ ~500miles Any feedback appreciated! Last edited by AlSuwaidi; 12-20-2009 at 12:46 PM. |
12-20-2009, 12:46 PM | #2 |
Bump!
Anyone?!? |
12-20-2009, 01:57 PM | #3 |
Drives: 89 IROC 350 Join Date: Mar 2009
yeah, you are probably engaging launch control. It holds the RPM at ~4000 rpm.
Did you fiddle with the TC button at all? Launch Control: In competition mode (two taps of the TC button) the DIC will display "competition mode" In neutral, hold accelerator on the floor, car will hold ~4000 rpm Put car in first and quickly lift off the clutch, its in your owners manual. There are several setting for the TC. 1 tap is TC off but stability control on 2 taps is competition mode which is TC off and stabilitrac at a minimum. a 7 second hold of the button is everything off. TC is just straight line traction (burn out) Stabilitrac is if you lose it in a turn it will back off the throttle automatically. Hope this helps... |
12-20-2009, 10:46 PM | #4 | |
Thanks for the feedback but its not LC. Maybe I didnt make myself clear in the original post but its definately not LC. LC kicks in at 4600 rpm (I have lots of experience with that including a broken driveshaft!) and when you double click the traction button till competitive mode displays on the screen. This happened when the car was moving. I was accelerating in 1st gear and when rpm hit 4 it just bounced back like when you hit the 6600 rom rev limiter! and I didnt touch the traction button so everything was on.. |
12-21-2009, 08:10 PM | #5 | |
12-21-2009, 10:26 PM | #6 | |
12-21-2009, 10:34 PM | #7 | |
There was a bit of tire spin cause like I said it was a dusty road.. Any other opinions? |
01-27-2010, 11:09 AM | #8 |
Drives: 2010 Camaro SS Join Date: Apr 2009
I remember having a similar problem (not the exacly the same tho) I was at WOT in the cobalt and when it reached about 5K it stopped and didnt want to climb to redline (7K) but thats where the simalarities end yours bounced as if it was hitting limiter where as mine didnt want to climb more. Ended up being a fuel system problem
Black on Black on Black 2010 Camaro 2SS LS3;K&N intake, Dynatech 1 7/8 catted LTs, Borla S Cat Back, Eibach prokit, Pfadt rear trailing arms, ZL-1 driveline, BTR Stage III Cam, Tuned by Performance Redline 444.1whp & 442.9 ft-lb
01-28-2010, 12:48 PM | #9 | |
H-Town Camaro Club Member
Drives: 17 Hyper Blue Metallic KLR-ZL1 Join Date: May 2009
Similar Threads | ||||
Rev Limiter | New 69 | 5th Gen Camaro SS LS LT General Discussions | 26 | 12-04-2009 01:45 PM |
rev limiter | oldfart1941 | 5th Gen Camaro SS LS LT General Discussions | 91 | 10-21-2009 09:20 AM |
2010 camaro ss rev limiter?? | mister_goods1 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 3 | 08-24-2009 06:23 PM |
Rev limiter | derin11 | 5th Gen Camaro SS LS LT General Discussions | 13 | 08-20-2009 11:52 AM |
rev limiter question | jordan 572 | 5th Gen Camaro SS LS LT General Discussions | 3 | 04-22-2009 10:00 PM |
