Old 08-12-2020, 09:37 AM   #1
Jtmurillo
Jtmurillo's Avatar
Drives: 2010 Camaro 2SS
Glue Residue From Stripes
Hello! I have just removed my rally stripes yesterday and am having a tough time getting the glue residue off. I was easily able to get it off on my trunk and Spoiler with goo gone but the hood is a whole new beast. I have tried goo gone (soaking for 5-10 min), WD-40, adhesive remover, polish on a drill with a pad, credit cards, microfiber towels. No luck on any of that. What worked for you? Any suggestions are greatly appreciated! Thanks! Name:  4BD13EBA-CE04-48FB-9519-6386AB37B507.jpg
Update: after reading through the comments, I have ordered a 3M eraser wheel from advanced auto parts. I will post another update once I have tried it to let you all know how it worked
Second update (after using the wheel): this thing is AMAZING. This was my last ditch effort before just buying a whole new hood. I worked and a local car detailer worked on the hood with usual tactics (goo gone, WD-40, adhesive remover spray, etc.) with no budge at all. In the picture I did half the top of the stripe (it looked the both on each half) and it took that residue off no problem! This thing is amazing and if used correctly and slowly will not damage your paint. I was skeptical but am so happy I gave it a shot. Thank you to everyone on this thread who helped me out and pointed me in this direction. Thanks!Name:  EDA51649-0DFF-4D05-8D20-8BAA9D16AA77.jpg
Jtmurillo is offline   Reply With Quote
Old 08-12-2020, 10:52 AM   #2
BAD DAB
BAD DAB's Avatar
Try this 3M wheel. It works great.
Old 08-12-2020, 10:55 AM   #3
Stingr69
'69 Owned Since '79
Stingr69's Avatar
3M Specialty Adhesive Remover solvent is the BOMB!!! Get it at the Auto Paint Supply store near you. Generally will not hurt painted surfaces but dissolves glue like crazy. I use it on many things. Great for replacing the glued on weatherstrips on my lacquer painted '80 Corvette.
Old 08-12-2020, 11:45 AM   #4
GodWentPunk
GodWentPunk's Avatar
Drives: 2015 2SS White Convertible CE/INDY
I used goo gone for autos when I had some glue left over from when I pulled off the dealer decals. After I was done, I put a coat of wax over everything.
joe...
ARH LTH/HFC/Legato muffler, RDP Custom Tune, K&N Blackhawk CAI, Bigworm Blackout kit, ZL1 Rims, Phantom Grills, VMAX PTB
GodWentPunk is offline   Reply With Quote
Old 08-12-2020, 12:52 PM   #5
ADVMax
Sporting Foole
ADVMax's Avatar
Drives: 2010 Camaro SS
Second that vote! I keep a can of that stuff all the time, it's versatile. Glue remover, adhesive remover, TAR remover..........
I prefer the rectangle can as opposed to the aerosol can.
ADVMax is offline   Reply With Quote
Old 08-12-2020, 01:32 PM   #6
Jtmurillo
Jtmurillo's Avatar
Is this easy to mess up your paint with?
Old 08-12-2020, 01:33 PM   #7
Jtmurillo
Jtmurillo's Avatar
Is this much more effective than WD-40 or Goo Gone? Because both of those did nothing to this residue.
Old 08-12-2020, 01:49 PM   #8
BAD DAB
BAD DAB's Avatar
When I removed my rear Bow tie emblem it left that thick adhesive that was hell to remove. The 3M adhesive removal wheel made short work of it. There should be a youtube video on how to use it properly. I had my fear of doing damage to my paint too. Believe me, it works without damage to the paint. Again, check out the youtube video first.
Old 08-12-2020, 02:00 PM   #9
InFiD3ViL
InFiD3ViL's Avatar
I have damaged paint with one. The best advice to to take the edge off and round it down before touching the paint. The sharp edges that are on it when new can cut through paint in seconds. Otherwise, they do work great. Just need to be very careful.
Edit: The one I damaged paint with was not a 3M, but some Amazon off brand (Whizzy Wheel?) - The one I used successfully was a 3M and used a softer compound which worked great.
Old 08-12-2020, 03:21 PM   #10
Spocktwin
Spocktwin's Avatar
Drives: 2015 LT RS Camaro, 1978 Trans Am
remover
Do a seach for Malco Label and Adhesive Remover. I have used it, has a strong smell but does the job. Doesn't harm the paint.
Spocktwin is offline   Reply With Quote
Old 08-12-2020, 03:37 PM   #11
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
Before you buy a whole bunch of products/tools for something you won't be using again, give your local detailer a call and see what they would charge.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 08-12-2020, 05:38 PM   #12
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Tooth paste
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 08-12-2020, 07:27 PM   #13
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Whatever window tinters use to remove old tint. On the rear window is the defroster. They can’t scape that glue off but use some kind of solvent.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 08-12-2020, 07:57 PM   #14
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
I’m really surprised this thread has so many suggestions. I would hope one worked and we all knew what it was.
Moto-Mojo is offline   Reply With Quote
