Old 02-10-2021, 02:29 PM   #1
Crazych66
Crazych66's Avatar
Drives: '12 Camaro 2SS/RS Vert
Question Manual Shift Lever Issue
OK I've searched and searched and haven't found a similar issue. I was replacing my shift knob in my '12 SS using the instructions to twist and pull... Well, I pulled the freaking shift lever right off the base of the shifter! I can put it back on, but it doesn't stay very well obviously.
Did I screw up/break the lever? Or is there a good way to reattach?
Appreciate the help!
2012 Camaro SS Convertible: 2SS, LS3, M6, Triple Black. Mods: Solo Axleback, 1LE FE6 rear swaybar, CAGS delete, Vararam CAI, Heritage grill, Hotchkis springs, '15 FE4 struts/shocks, ZL1 side rockers, Velgen Classic5 wheels, Pedders radius rod bushings, ARH LTHs, gutted HFCs,...
Crazych66 is offline   Reply With Quote
Old 02-10-2021, 02:32 PM   #2
Crazych66
Crazych66's Avatar
Old 02-11-2021, 08:46 AM   #3
cawengr
Drives: Classy
Looks like the shift lever is toast. The section that pulled apart is the molded section (rubber) there for vibration isolation.
I don't know of any way to fix this unless you try drilling a small hole (3/16) through both the shifter and rod then put a pin through both to hold it together.
Better solution is just replace it with a Hurst Shifter
cawengr is offline   Reply With Quote
Old 02-11-2021, 09:08 AM   #4
Stingr69
'69 Owned Since '79
Stingr69's Avatar
I have a low mileage 2010 take-off shifter assembly. Should work fine. I pulled it out early on to put in a Hurst shifter. $25 plus the ride if it would help you.
Old 02-11-2021, 10:25 AM   #5
Crazych66
Crazych66's Avatar
Aaaah! Thanks. My first thought was to try to glue it, though I'm not sure how that would hold up.
Old 02-11-2021, 11:31 AM   #6
Crazych66
Crazych66's Avatar
Thanks. Do you have pics of the assembly you can send?
Old 02-12-2021, 12:33 PM   #7
Stingr69
'69 Owned Since '79
Stingr69's Avatar
I sent you a PM
Old 02-14-2021, 10:12 AM   #8
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Its about $11.50 for the ride if you want it.
Old 02-15-2021, 09:27 AM   #9
Crazych66
Crazych66's Avatar
Thanks I'll let you know today. I'm bidding on a Hurst shifter and if that falls thru I'll take yours.
Old 02-16-2021, 07:10 AM   #10
Crazych66
Crazych66's Avatar
Sending you a PM.
Old 02-17-2021, 12:21 PM   #11
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10
I have an OEM Hurst short-thrown that came stock with my 2013, if you're interested. I installed a MGW.
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
