Old 04-03-2010, 07:08 PM   #1
Nate33
Drives: 10 Camaro RS 2LT, 11 Avalanche z71
preoblems with K&N CAI after installation
Anyone have issues with car starting after installing K&N intake for v6? Car starts up for 2 seconds and shuts right off. Emissions sensor maybe or some anti-theft crp?
Nate33 is offline   Reply With Quote
Old 04-03-2010, 07:16 PM   #2
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Couple things....
Is the MAF plugged back in?
Not sure how the K&N is built... but is the MAF "housing" backwards?
scrming is offline   Reply With Quote
Old 04-03-2010, 07:19 PM   #3
scrming
scrming's Avatar
Ok... looks like you really can't have the MAF in backwards...
Every thing tight? PCV tube connected?
Old 04-03-2010, 07:33 PM   #4
Nate33
99% sure I put on correctly. Have done before on my 06 tahoe.
Reading manual...emissions sensor was noted as well as anti theft. but all other posts of folks putting CAIs on I never saw any problems so chances are its something I did. Any kind of reprogramming for the onboard computer necessary?
Gave up for the night and will get back at it in the morning with fresh start
Old 04-03-2010, 07:36 PM   #5
Nate33
also...engine light is on now
Old 04-03-2010, 07:40 PM   #6
scrming
scrming's Avatar
hmmm... double check everything in the morning... if still no luck then perhaps put the stock intake back on and drive down to the local Autozone type place and have them pull the trouble code...
You should NOT need to reprogram the computer..
Old 04-03-2010, 07:51 PM   #7
Nate33
Thanks for the reply. Will check it out in the morning. Have a good one.
Old 04-03-2010, 08:37 PM   #8
devildoc
devildoc's Avatar
Drives: '12 Toyota Tacoma Dbl
Could possibly the #5/20 have anything to do with it? Something electrical from the setup...
STANDING 1/4MI: 13.948@99.87
6600RPM HP/TQ Gains - 30.54HP/24.3TQ (NOT PEAK)
devildoc is offline   Reply With Quote
Old 04-04-2010, 06:22 AM   #9
Beauwulf
Beauwulf's Avatar
Drives: '10 LT RS A6 & '04 Acura RSX Type S
check next to the PCV tube on the head. There is a plug there for the cam position sensor. You might have pulled it off during the install....
Beauwulf is offline   Reply With Quote
Old 04-04-2010, 06:36 AM   #10
carguy50
carguy50's Avatar
Drives: 2SS/RS, Sequntials,Tune,Flomstr,CAI
Did you get the pre-oiled or dry K&N.if you bought the pre=oiled one, they tend to over oil the filters and then too much oil can contaminate the sensor. It happened to me with my Hemi 1500. The fix is wash out the filter with Dawn and hot water,dry it, clean the sensor thoroughly with rubbing alcohol. Reinstall the clean unit. Reset your codes and enjoy.
carguy50 is offline   Reply With Quote
Old 04-04-2010, 08:19 AM   #11
scrming
scrming's Avatar
couple things... I've use oiled filters, including the K&N OEM type panel filter for our cars... and while it looked a bit over oiled it did not cause any problems. I think people are way to quick to blame an oil filter... Also if you are going to clean your MAF i would suggest a MAF cleaner spray like:
And by the sounds of it, the car never really started and ran to even really contaminate things..
Beauwulf's suggestion is a good one... We've had a car run rough on here after a CAI install, but I don't we've had one just shut right off...
Old 04-04-2010, 08:23 AM   #12
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
As one stated, maybe a fuse pull/battery unplug is in order(to re-learn?)
Old 04-04-2010, 08:30 AM   #13
Nate33
youre right...engine never really had a chance to do anything. would turn over and shut right off. Pulled the ECM fuses few minutes ago. going to grab breakfast and check it out after cup o joe and egg sandwich.. Thanks
Old 04-05-2010, 10:44 PM   #14
GUNIT
RKFDGEO- chicago5thgen
GUNIT's Avatar
Drives: 2010 2LT/RS SIM Auto
Send a message via AIM to GUNIT Send a message via Yahoo to GUNIT Send a message via Skype™ to GUNIT
Had my K&N installed tonight. Had same problem, shutting off right away. Turns out we had the MAF in backwards. All fine now. I think thats what the piece was called. The one going into the tube.
GUNIT is offline   Reply With Quote
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3652 08-17-2023 02:50 PM
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 10:40 AM
K&N CAI For a V8 2SSRS@Gen5diy V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 15 12-25-2009 02:14 PM
New K&N Typhoon CAI??? What do you think?? Jeffro Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 12-23-2009 01:28 PM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 09:10 PM
