12-17-2012, 03:59 PM | #1 |
Drives: 2013 Camaro ZL1 Join Date: Dec 2012
LINGENFELTER 630HP PACKAGE DYNO RESULTS
Package Installed and tuning done by SPEED INC, Shaumburg IL. Is a 2013 Automatic Camaro ZL1.
This is what the Lingenfelter Package includes: - L650162012 Lingenfelter High Flow Camaro ZL1 Cold Air Intake LSA 2012-2013 - L250150309 Lingenfelter CTS-V Camaro ZL1 LSA LS9 10 bolt Supercharger Pulley Hub - L220300709 Lingenfelter CTS-V Camaro ZL1 LSA 2.55 8 Rib 10 Bolt Pulley - L960130709 Lingenfelter Supercharger Isolator Coupling LS9 LSA Engine 2009-2012 - 8PK1655 8 Rib Poly V Belt CTS-V For LPE 2.55 Inch Upper Pulley - L310065307 Lingenfelter 160 Degree Thermostat |
12-17-2012, 04:14 PM | #2 |
Drives: 2002 TT Trans AM/ 2007 TBSS Join Date: Dec 2010
Thank you for your business, we appreciate you bringing the car in. We need to upgrade those injectors next time we see you!
12-17-2012, 04:15 PM | #3 |
Drives: 2013 zl1 Join Date: Nov 2012
thats a great number for auto car.. bet it runs it ass off..
12-17-2012, 09:28 PM | #4 |
Drives: Camaro ZL1 Join Date: Dec 2012
Very nice!
Was there a "before" run, to see how much of a gain you had?
12-17-2012, 09:53 PM | #5 |
Just air intake and supercharger pulley brought it up to 570wHP.. wow
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
12-17-2012, 10:24 PM | #6 |
A average auto car makes 460-70.. a good air cleaner and tune is worth 50 alone.. its usually 20 or so hp per pound of boost added..
12-17-2012, 11:09 PM | #7 | |
ZL1 is what 14psi 16 or 18psi
12-17-2012, 11:16 PM | #8 |
15 pounds on pump is safe.. I can say that.. blower seems to turn into a bit of a heat pump over 16..
12-18-2012, 08:01 AM | #9 |
Drives: 2017 ZL1 A10 Join Date: Sep 2009
WOW, those are good numbers for automatic with just a cai and upper pulley. Are you sure they didn't slip you the 700 package?
2017 ZL1
A10 Redhot with stripe |
12-18-2012, 09:13 AM | #10 |
Petro-sexual
Nice numbers
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
