Old 10-30-2016, 12:33 PM   #1
Oshawan
Drives: Camaro
2010 v6 "Pwr reduced service stabilitrack!" Throttle body?
I've read quite a few threads and am wondering if the consensus with this problem and reduced power is a known throttle body issue? Others have found loose wires and plugs to be the culprit. 40,000miles only.
I swapped out my throttle body for the vmax in May. I have reached out.
My mechanics had a look but can't figure it out. Reduced poweer and alomost stall on takeoff.
Any links appreciated
Mark/Oshawa
Oshawan is offline   Reply With Quote
Old 10-30-2016, 11:07 PM   #2
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Did you try unhooking the battery in the trunk over night, to force a relearn from the computer with your throttle body. Try that first. I remember there was some other things to try too, but will need to look them up in the 3 book manual. Did it trip a code? if so what was the code number too.
Old 10-31-2016, 12:43 PM   #3
tlavoie87
Built Not Bought
tlavoie87's Avatar
Drives: 2010 Twin Turbo LFX
when i was having the same issue it was caused by a misfiring issue..
2010 Twin Turbo LFX
In Memory of my DAD Gone but never Forgotten 2014
"Built Not Bought!'
Sponsors:
OverKill Motorsports
tlavoie87 is offline   Reply With Quote
Old 11-01-2016, 12:16 PM   #4
djrasras
djrasras's Avatar
Drives: 2010 2LT Bumblebee
I had this problem for literally a year, could be a number of things, in the end for me it was misfiring due to a spun bearing. But until then I checked the battery wires, the battery itself, removed my Vitesse Throttle Controller, etc. But I actually never went back to my stock throttle body, because I had my Vmax on for a couple years before having this problem. So ya check/remove all those things and work from there.
AirLift Air Suspension, Stainless Works Long Tube Headers + Hi-Flo Cats, Resonated X-Pipe, MRT V2 Mufflers, VMAX Ice-olator and Ported Throttle Body, Barton Short Throw Shifter, CAI Intake + Air Scoop
djrasras is offline   Reply With Quote
Old 11-01-2016, 10:27 PM   #5
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Mass air flow sensor probably. Clean it with mass air flow sensor cleaner.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 11-02-2016, 08:43 AM   #6
sir574
sir574's Avatar
Drives: 2017 SS 1LE
Or replace it, that fixed a lot of my issues.
sir574 is offline   Reply With Quote
Old 11-04-2016, 09:26 PM   #7
2010_camaro
That too but cleaning is a cheaper alternative. If it works you save money if not you're out $5.
