08-28-2014, 05:52 PM | #1 |
Drives: 2014 2SS/RS Convertible - Red hot Join Date: Jul 2014
How Much oil did you lose after first 1200 miles
Looks like she is down a quart.....Is that normal compared to others?
08-28-2014, 05:55 PM | #2 |
old school chevy rodder
no
08-28-2014, 06:15 PM | #3 |
I think I checked it right, manual says to check it warm so I went for a 20 min cruise, parked it in the driveway and checked it. It was up to the bottom line.
08-28-2014, 06:18 PM | #4 |
Drives: 2013 2ss Join Date: Aug 2014
Loose as in leak and/or burn? None.
08-28-2014, 06:20 PM | #5 |
I dont see any leaking anywhere, so I would say it burned it. I dont really notice any smoke though while reving or anything like that either...
08-28-2014, 06:34 PM | #6 |
I also did not check it when I got it from the dealer so could have been gone already or not filled all the way. Ill have to fill it up and see where it goes from there.....
08-28-2014, 07:11 PM | #7 |
Drives: 2015 Camaro SS Join Date: Sep 2011
I didn't add any oil and I did my first oil change at 1,800....let it sit awhile as the oil seems to take some time bleeding down to the pan
2015 Camaro 2SS Cam/Heads/FBO 498/447 SAE |
08-28-2014, 07:15 PM | #8 |
Drives: 14 1LE Join Date: Mar 2013
Also note that the 8 qt. mark on the dipstick is in the middle of the crosshatch area, not the top like one would think.
LMS Engineering
08-28-2014, 07:20 PM | #9 |
Drives: 2014 2SS L99 Join Date: Mar 2014
Ours just turned 1000 last week and no measurable oil drop on dipstick from new. Ours was originally filled to the top cross hatch marks when we received it.
08-29-2014, 06:55 AM | #10 |
Call Me"Doc"
Drives: 2014 2SS/RS 1LE BLACK Join Date: Apr 2009
If you checked it immediately after turning the engine off, it can read a touch low. In 1200 miles you shouldn't lose much if any, but a little over a lot of miles isn't a big deal.
08-29-2014, 07:20 AM | #11 |
Drives: 2014 Ford Mustang GT Premium Join Date: Jul 2014
08-29-2014, 07:59 PM | #12 |
C5 Best Gen
Drives: 2015 Camaro SS Join Date: Aug 2013
No.
08-30-2014, 05:51 AM | #13 |
Drives: '14 2SS/RS Vert 6M/KTU/NPP/DTA/ARH Join Date: Jan 2014
Check it first thing in the morning after it has completely cooled down and make sure it's on a level surface. It is damn near impossible for them to put the incorrect volume of oil in the engine at the factory. Mine has burned no oil at all in 4500 miles.
Consensus is, by definition, a lack of leadership.
08-30-2014, 10:16 AM | #14 |
Thanks Everyone. I tried this again and waited about 10 minutes before checking. It looked much better. The oil was 1/4 way down from the top line. So if the 8 qt mark is in the middle then thas means I am right in the ball park, maybe a little over.
