Old 03-21-2016, 03:27 PM   #1
500rwhp
Cocaine
500rwhp's Avatar
Drives: 2015 White 1SS/RS/1LE*NPP*RECAROS
oil seperator
hey any of guys/gals put that stock oil separator in your car that you got from GM with our cars. I daily my car and take it to the dragstrip here and there.. should I put this on. I was told only for when using at the track... is this true... any help would be great.
thanks
500rwhp is offline   Reply With Quote
Old 03-21-2016, 04:02 PM   #2
kmdracer
Drives: 2015 black 1SS 1LE
Mine was put on by dealer when I bought the car. I never take it off, lol. Soon to be getting a catch can as well. See my thread in the 1LE forum for a picture of intake.
2015 Black 1SS 1LE.
kmdracer is offline   Reply With Quote
Old 03-21-2016, 04:17 PM   #3
Camarotobeornottobe
Drives: 1LE
OP, the reason it is technically only for off-road use is that, in temps below 32 degrees, moisture can collect it in and eventually run into the crankcase. That moisture will then compromise your oil and be bad for the engine. Theoretically.
So, if you drive year round, you will want to take it off in the winter. Otherwise, there are no negative side effects .
Camarotobeornottobe is offline   Reply With Quote
Old 03-21-2016, 07:32 PM   #4
Tunamanz
Tunamanz's Avatar
Drives: 2015 2SS 1LE
Contact Steve at Elite Engineering and he will take care of you. There cans are the best in the business. These videos might help as well:
http://www.camaro5.com/forums/showthread.php?t=441757
Tunamanz is offline   Reply With Quote
Old 03-21-2016, 07:45 PM   #5
clarkkent
Drives: 2013 2SS (sold)
This clean side catch can is only really necessary for the track, as the flow is usually INTO the valve cover from the intake tube. Only under WOT does the crankcase build up enough pressure to push oil vapor back up into the intake tube. Hence why you'd use it while racing
clarkkent is offline   Reply With Quote
Old 03-22-2016, 08:09 AM   #6
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
Living in SE GA, the car never sees temps below 40 (usually), so I left ours on as it was installed at the dealer. If the car were to experience cooler temps, I would not leave it on for condensation / freezing reasons.
gajagfan is offline   Reply With Quote
