09-10-2023, 02:38 AM | #1 |
Drives: 18 1SS Join Date: Jul 2023
Anyone with LT5 Cam on an LT1 Engine
Hi,
I'm looking to go back to stock cam in my car as I'm not really liking the drivability on low RPMs of my BTR 225 Cam. Currently looking to install the LT5 Cam (instead of my Stock LT1 Cam) to utilize the aftermarket lifter, pushrods, springs already in the car. So, anyone with experience with the LT5 Cam? Will it drive and sound completely like the factory Cam? Anyone have any experience with this LT5 Cam? It's priced well. Appreciate the help and clarifications. |
09-10-2023, 07:31 AM | #2 |
Drives: 2019 2SS Camaro Join Date: Apr 2012
well thats what i put in my car lt1 2ss. Drives like stock. Theres some controversy on whether its specks are the lt4 or the same as the ss. Im thinking its the same specks as the lt4.
Ask btr they said same as lt4. and also btr makes a stock lt1 cam that is the same as the lt1 just no dod. Either way both cams drive like stock completely just I would think u need boost with the lt4 specafcations I am boosted so. |
09-10-2023, 09:07 AM | #3 | |
09-10-2023, 09:47 AM | #4 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
Kerry is correct that originally the LT5 cam specs were confused with the L86. It's actually similar specs to the LT4 minus the DOD/AFM lobes. I would not run that cam in your NA application.
I would go with the BTR stock profile DOD delete cam. It uses the larger LT1/L86 specs. https://briantooleyracing.com/btr-ca...240006175.html They also offer one with a 32% fuel lobe for those who plan on going forced induction and need to overdrive the high side pump for more fuel headroom. https://briantooleyracing.com/btr-st...fuel-lobe.html
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
09-10-2023, 09:53 AM | #5 | |
09-10-2023, 11:13 AM | #6 |
Question. Im boosted with a procharger. thinking it might make a little better power with the lt1 speck cam and add lift on the exhaust to be at least as much as the intake.
What ya think King? |
09-10-2023, 11:16 AM | #7 | |
Appreciate your clarification. |
09-10-2023, 11:20 AM | #8 | |
The first link I posted is the correct cam for what you want to do. Getting a part at A great price isn't always the great way to go. I would do the btr dod delete cam I linked or step down to the v220.
2016 NFG 1SS A8
09-10-2023, 12:57 PM | #9 | |
My car has Full Boltons (Headers, CAI, Intake Manifold), how much less horsepower at the wheels are we expecting from installing the LT5 Cam compared to the LT1/BTR LT1 style in in Full Bolton applications? is it huge difference or just some minor 5-10 whp? |
09-10-2023, 03:18 PM | #10 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
I'd swap the stock valve springs back in also if going back to a stock spec cam. Seat and open pressures with the BTR springs are way higher than you'll need with a stock cam. No reason to beat up on the lifters, rockers, seats, etc when you don't have to
Baby Blue
2016 Hyper Blue 2SS/6m/MRC/NPP/Silver Rally stripes/ZL1 wheels & brakes/GForce DS and axles/ZLE Cradle Bushings/FE4 ARB front & rear/SEMA Grill/Rotofab dry/95mm TB/Magnuson 2300/Full LT4 fuel system/JMS boost-a-pump/E85 Sensor/Ported CID heads from LME/Cammotion PD cam/Thompson Motorsports forged shortblock/catted Kooks 1 7/8 headers /JRE remote tuned |
09-10-2023, 04:14 PM | #11 | ||
Drives: F-Series Canyonero Join Date: Nov 2020
Coming out of warranty, I'm looking to install a k-tech oil pump and ideally more reliable lifters. Is the LT1 Camaro cam the same as a truck cam? From the product description: Quote:
09-10-2023, 05:29 PM | #12 |
Drives: 21 SS Join Date: Oct 2017
Maybe go down to btr 220 or Katech torquer instead
09-10-2023, 08:32 PM | #13 |
Drives: 2017 Nightfall Grey 2SS 6 Speed Join Date: Jan 2022
09-11-2023, 12:23 AM | #14 |
Honestly i don't want to risk it no more with other aftermarket cams as i dont trust their “stock” drivability claims no more. Thats why im trying to stick with stock cam and enjoy the stock drivability.
