#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > V8 LT1 Engine, Exhaust, and Bolt-Ons
AWE Tuning
Old 03-13-2024, 05:15 PM   #1
16ssFR
Drives: 2016 Camaro 2ss
Misfiring on E85
Mods: LT2 manifold, Roto Fab CAI, Headers, X pipe , DSX Flex Fuel Sensor, and Tune.
Has new spark plugs and wires. Also tried moving around wires and spark plugs but no luck.
The misfire only happens on E85 and when I pump 93, it goes away. Checked logs on scan tool and only happens on cold start at arounf 1,200 RPM. Seems to be only happening on cylinder 2. Cylinders 4, and 8 have maybe 10 misfires but hundreds on cylinder 2.
During tune logs, Throttle body would open 56% at WOT. Saw in another forum that having a stock 87mm TB may cause the issue. Ordered a 95mm TB but want to get some feedback.
Any help would be really appreciated.
16ssFR is offline   Reply With Quote
Old 03-13-2024, 05:48 PM   #2
cjperformance
cjperformance's Avatar
Drives: 2017 Camaro SS 50th Anniversary
E85 is harder to ignite esp cold. Thats one reason they still add 15% gasoline. Maybe weak coil on that cyl?
2017 50th Anniversary Edition | P1X Stage 2
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
cjperformance is offline   Reply With Quote
Old 03-14-2024, 08:05 AM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Is it misfiring enough to trigger a CEL or you are just seeing some misfires in the log? Because it's pretty normal to get some cold start misfires on E85. Part of the reason why they drop the E content down in the winter months. E likes heat and doesn't like cold.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP
Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA
KingLT1 is offline   Reply With Quote
Old 03-14-2024, 11:56 AM   #4
ctrlz
Drives: 2017 2SS, 50th pkg, M6, MRC, NPP
Good first idea!
try swapping it to other side. If not spark problem, then take a look at fuel trims.
ctrlz is offline   Reply With Quote
Old 03-15-2024, 07:18 PM   #5
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
Did you change the spark plugs and wires after the misfires started happening? Or they started happening after you changed the plugs and wires? If so I would double and triple check the wires are all seated and that you didn't crack a insulator and spark is leaking. Also are they iridium tip? If you even touch the inside of an iridium tip plug with metal it will cause a misfire, that's why they tell you not to try to check or set the gap on them.
It is a random misfire code? or is the check engine light continuously flashing?
cmitchell17 is offline   Reply With Quote
