08-20-2010, 06:59 PM | #1 |
Drives: 2011 2SS m6 Join Date: Apr 2010
First oil change copmplete. BUT
OK did my first oil change, used Pennzoil Platinum and a Mobil 1 filter. Put the car up on rhino ramps drained the oil, removed the oil filter, so far everything is going well. Installed new filter tightened everything, poured the first 5qt's of oil from the jug, then poured another 3 from the other jug making sure I left 2qts behind. Started the car lowered it off the ramps, checked the dipstick(which sucks by the way) and I was hair over the hash marks. I decided to go for a drive let it warm up move the oil around. While driving I noticed that the oil pressure gauge is slightly higher than normal, it used to be at the mid point between 0-30, now its just 2 needles over that mark. Also I don't know what the normal oil temps were before, I was hoovering around 200-215. I get home pop the hood and check the dipstick a couple of times, and I'm still just above the hash marks. What should I do, I don't want to damage anything. I need suggestions, this will bother me all night...
7/7/10 Status: Delivered
08-20-2010, 07:17 PM | #2 |
Drives: 2016 Mazda6, 2011 Mustang 5.0 Join Date: Mar 2010
My dad's Miata does something similar. Depending on the filter used, I've seen the oil pressure vary between 40lbs and 60lbs at hwy RPMs once fully warmed up, and between 60lbs and 90s lbs when cold.
If it's just a little over the full mark, I wouldn't be worried about the level either. (As long as it is not way over filled).
2022 1SS 1LE (Arrived 4/29/22)
"The car is the closest thing we will ever create to something that is alive." . 2022 1SS 1LE (Coming Soon) |
08-20-2010, 07:32 PM | #3 |
Drives: 69Camaro,87IROC,96 SS,Z06&Stingray Join Date: Apr 2010
I agree the oil pressure is probably a function of oil temperature and pressure drop across the filter, not oil level.
Some filters will catch smaller particles, but with a trade off of being more restrictive. You could always change to a different brand of filter and see what the oil pressure does. I prefer WIX filters, and use them on all my cars. |
08-20-2010, 07:49 PM | #4 |
Go Blue!!!!!
Drives: 2012 Cruze LT Join Date: Mar 2009
If you put the right amount of oil in it, don't worry about it.
08-20-2010, 08:11 PM | #5 |
Well I put 8qts in, but I now think there could be some residual from draining up on ramps. I'm not worried about the pressure since its just slightly higher, plus I agree its probably due to the filter. My main concern is the excess oil.
08-20-2010, 08:15 PM | #6 |
Go Blue!!!!!
Yeah, if you did not level the car out, there is a good chance you did not get all the oil out. Personally, I jack the car up drain the oil out and lower the car back down to get all the oil out. There is quite a bid of oil that will come out when I let the jack down. Hate to say it, but you might want to do it again. Wait for a few more responses before you decide. There are some really smart people on this forum.
08-20-2010, 08:20 PM | #7 |
Drives: 2010 2SS/RS ; 1970 Firebird Formula Join Date: Jan 2010
I have never seen oil sold in 5 quart jugs????? What the????
08-20-2010, 08:22 PM | #8 |
In the back of mind I'm thinking I have to do it again, now the question is after I drain the oil can I reuse it?
08-20-2010, 08:26 PM | #9 |
Go Blue!!!!!
You probably could, but I would not. I would bite the bullet and buy new. Again, that's just me, and your probably fine not doing that, except you'll have to be sure to measure correctly whereas buying new it is already measured.
08-20-2010, 08:27 PM | #10 |
Walmart carries it in 5qt jugs, go figure most stores carry it in 4qt. Just my dumb luck.
08-21-2010, 07:11 AM | #11 |
Alright for peace of mind I'm going to drain the oil and put new oil in, correct me if I'm wrong but the filter does not need to be replaced. Now I figure there will be at least a qt in the filter and probably half a quart of residual in the pan. So I'll start with 6.5 quarts, lower the car off the ramps and check the dip stick. Does this sound good, I don't have a Jack so lowering the car to drain any more oil from the pan is not feasible, plus I prefer not to remove the filter.
08-21-2010, 10:26 AM | #12 |
Drives: '10 SS CGM #75,288, '14 Stingray Join Date: Aug 2009
08-21-2010, 10:38 AM | #13 |
Drives: 2010 2SS Join Date: Jul 2010
Dont drain oil......... Thats a waste.
if your worried about being over the hash mark then just drain a cup full out and be on your way. Me id leave it and drive it......... its totally fine. If your blowing oil outa air box then you have way to much. Leave it and save your money. |
08-21-2010, 11:05 AM | #14 |
It's a sickness!
Drives: '69 442 Vert Join Date: Dec 2009
I agree, just drain some of the oil out and roll the car off the ramps. Check the oil on a level surface and add to the full line. You said you had some oil left, so take out enough the first time and not have to repeat. the process.
Similar Threads | ||||
DIY: Camaro Oil Change | adub4185 | Camaro DIY & HOW-TO instructions & discussions | 180 | 04-23-2014 06:11 PM |
Oil Capacity LS3 | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 77 | 04-21-2014 10:19 PM |
best synthetic oil to use | hollywoodjose | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 130 | 01-26-2014 08:51 AM |
3,000 Miles - No "Metal Shavings" - Anyone Else? | FNKNSTN | 5th Gen Camaro SS LS LT General Discussions | 48 | 10-05-2009 11:46 PM |
Major U.S. oil source is tapped | KILLER74Z28 | Off-topic Discussions | 32 | 10-30-2007 09:47 AM |
