04-07-2013, 11:22 AM | #1 |
Drives: 1967 camaro Join Date: May 2011
LG G6X3 CAM
I sold my short block and this is what I have left.around 10kmiles
$400 |
04-07-2013, 03:51 PM | #2 |
Smoke'm if you can
Drives: 2010 Camaro 2SS/RS/LS3/M6 Join Date: Nov 2012
What else do you have? Spring and rods for this cam? PM me please
Texas Speed LT Headers with HF Cats, Borla ATAK Exhaust, MGW Short Throw Shifter, ADM CAI with Scoop, Elite Oil Catch Can, Mishimoto Aluminum Radiator, Pedders XA Coilovers, Mantic Twin 9000 Clutch, PFADT Solid Subframe Bushings, PFADT Front & Rear Sways, PFADT Upper Control Arm Bushing, PFADT Trailing Arms/Tie Rods, Whiteline Adjustable End Links, Whiteline Adjustable Lower Control Arms, Pedders Diff Bushings, Line Lock, ACC Side Markers, ACC Reverse Lights, Custom Tune from Nitrous Express.
04-07-2013, 06:03 PM | #3 |
Nothing just the cam and sprocket
04-07-2013, 06:04 PM | #4 |
ls2 cam sproket.the cam is 3bolt cam
04-10-2013, 10:05 AM | #5 |
Pm's replied
04-11-2013, 12:55 PM | #6 |
Picked up or shipped. I will not drop it off at your location unless you pay in advance.
Thanks, Sam |
04-15-2013, 04:43 PM | #7 |
To the top
04-16-2013, 07:56 AM | #8 |
Drives: 2010 CGM 2ss/rs M6 Join Date: Feb 2012
What IsThe Lsa OnThis Cam ?
04-16-2013, 08:27 AM | #9 |
Enjoys a good train wreck
Drives: 2010 IBM Camaro 2SS/RS Join Date: Nov 2009
It's over .610 lift, and more than 230/240 duration Those are the exact words copied and pasted from a message from Anthony at LG Motorsports. I have this cam and love it. Makes a ton of power in the higher RPM range.
04-16-2013, 02:44 PM | #10 |
Thanks drew
04-16-2013, 04:46 PM | #11 |
Lsa 111.
$350 . Last edited by sic7; 05-09-2013 at 10:32 PM. |
05-09-2013, 10:33 PM | #12 |
Bump..
05-10-2013, 07:54 AM | #13 |
Smoke'm if you can
I was going to buy this cam from you just so you know. I called LG and inquired about the springs/rods and gaskets/bolts, timing chain ect. Just to buy all the stuff required to install that cam, it was $150 off what it cost to buy a brand new kit from them. Crazy I thought. Just so you know.
05-10-2013, 02:04 PM | #14 |
I also have a ls2 chain kit.with both sprokets and new ls3 head gaskets.both items are new
