Old 06-22-2014, 03:36 AM   #1
on3wego
on3wego's Avatar
Drives: 2014 zl1 triple black
Max boost on new heartbeat
Does anybody know what the max boost is for the 2.3 heartbeat? I'm not looking to go full boost.. but iv tried reading and finding info.. can't find any.. idk what is max for this blower.
Might pulley swap later on... way later on.. may not even have it touched. But just the knowledge is what im.wanting.. what psi? What's it produce out of the box?
on3wego is offline   Reply With Quote
Old 06-22-2014, 06:17 AM   #2
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
Zl1 has a 1.9 not a 2.3. Mine 2012 was at13.5 with no issues and I believe there are people pushin 16 on this site
joes407 is offline   Reply With Quote
Old 06-22-2014, 06:42 AM   #3
on3wego
on3wego's Avatar
I know it has 1.9.. upgraded to the 2.3 heartbeat
Old 06-22-2014, 08:51 AM   #4
Trevorlj
Drives: '11 CTS-V Coupe
The 2.3's published compressor map extends to 2.4 pressure ratio (20.6 psi at sea level). Doesn't mean that's a good idea. The 2.3's efficiency drops off pretty quick above 14.4 psi. I probably wouldn't exceed 18.7 psi while drag racing at sea level on a stock size motor. Road race, go up in altitude, or strap it to a larger motor and you'll need to drop the boost to keep the charge air temps reasonable.
Just as a side note if you bounce the map off of theoretical airflow numbers the 2.3 really needs to be on a larger motor to do it's best work. Sweet spot should be around a heads & cam 442 (I wish) at 13.8 psi on standard day. ~950 crank HP
Trevorlj is offline   Reply With Quote
Old 06-22-2014, 09:06 AM   #5
Botally Tone
Drives: 2014 Ashen Gray ZL1
Boost is all relative to what you have done to your engine. What it produces out of the box is going to depend on your headers, heads, exhaust etc.
Botally Tone is offline   Reply With Quote
Old 06-22-2014, 09:10 AM   #6
Baer383
Baer383's Avatar
Drives: 2013 ZL1 Ashen Gray
You don't go by boost you go by blower speed!
I don't have to know everything,I just need to know,what I need to know,when I need to know it!
MODS, a lot of money,a lot of parts,a lot of time,a lot of patience.
754 RWHP 747 RWTQ 93 Octane
http://www.camaro5.com/forums/showthread.php?t=347243
Baer383 is offline   Reply With Quote
Old 06-22-2014, 09:31 AM   #7
Trevorlj
Blower speed isn't quite the issue with the 2.3. Requires ~2-3k less RPM to move the same air with the 2.3.
Old 06-22-2014, 09:32 AM   #8
Baer383
Baer383's Avatar
Originally Posted by Trevorlj View Post
Blower speed isn't quite the issue with the 2.3. Take ~2-3k less RPM to move the same air with the 2.3.
blower speed is always the issue,that like saying your RPM's aren't a issue.
Old 06-22-2014, 09:38 AM   #9
Trevorlj
Let me put it another way...you're never going to get to extreme right side of the 2.3 blower chart with a stock-ish motor. The LSA is way too small.
I don't know how else I can explain it to you.
Old 06-22-2014, 09:38 AM   #10
GenF-GTS
Drives: none
You should really look into your final compression ratio before going all out.
you work it out like this -
Final Compression Ratio = (Boost / 14.7) + 1) x CR
So 15psi would look like this:
15psi / 14.7 + 1 x 9.1 = 18.38:1
so 18.38:1 comp
Basically that's a lot of pressure on the cylinder walls and piston, and head gasket, head bolts, head.
GenF-GTS is offline   Reply With Quote
Old 06-22-2014, 09:43 AM   #11
Baer383
Baer383's Avatar
The OP motor isn't stock
You don't have to explain it to me your post wasn't filled with all the info,the speed is always the factor,the HB won't exceed blower speed until you put it on a 427 cid of bigger engine or over spin it to get more psi.
My point is none of you have address this blower efficiency issues,just b/c it is the HB doesn't mean blower speed is exempt.
Old 06-24-2014, 04:54 PM   #12
on3wego
on3wego's Avatar
Car will be finished Friday. Start up today
