09-08-2011, 06:53 PM | #1 |
"To Punish And Enslave"
Drives: B E RS GBA #72541 3564 CC 220 CI Join Date: May 2011
How Do You Reset TPMS?
got my new rims and tires on (get link to thread when updated). And they installed the sensors in my rims but i am still geting the warning light. I will have them check it tomorrow. But incase i can fix it myself how do i do it thanks
C.A.M.A.R.O- Constantly Adding Modifications Addiction Relentless Obsession 90% canadian 10% mexican 100% american muscle :flag2: |
09-08-2011, 06:54 PM | #2 | |
SoCal Mayhem
Drives: 2010 Camaro 1SS/RS Join Date: Aug 2008
Check the manual
09-08-2011, 06:58 PM | #3 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
If you have a 2011, you have to take the car to the dealer to have th enew TPMS calibrated to the car. It takes a special hand held device to do it.
BTDT when I bought my new rims/tires. You CANNOT do it the old fashioned way by changing the tire pressure at each wheel one at a time like you used to be able to do. The good news is my dealer told me that any time I want to change my wheels, just bring it in and they'll re-calibrate the TPMS sensors for free. It only takes a few min. |
09-08-2011, 06:58 PM | #4 |
09-08-2011, 07:01 PM | #5 |
SoCal Mayhem
09-08-2011, 07:09 PM | #6 | |
09-08-2011, 07:55 PM | #7 |
Drives: 2011-1LT RS COUPE Join Date: Aug 2011
2011 manual says it can be done either way
TPMS Sensor Matching Process Each TPMS sensor has a unique identification code. Any time you replace one or more of the TPMS sensors or rotate your vehicle's tires, the identification codes need to be matched to the new tire/ wheel position. Also, the TPMS sensor matching process should be performed after replacing a spare tire with a road tire containing the TPMS sensor in order for the malfunction light and the DIC message to go off at the next ignition cycle. The sensors are matched to the tire/wheel positions in the following order: driver side front tire, passenger side front tire, passenger side rear tire, and driver side rear tire using a TPMS diagnostic tool. See your dealer for service. The TPMS sensors can also be matched to each tire/wheel position by increasing or decreasing the tire's air pressure. If increasing the tire's air pressure, do not exceed the maximum inflation pressure indicated on the tire's sidewall. To decrease the tire's air-pressure use the pointed end of the valve cap, a pencil-style air pressure gauge, or a key. You have two minutes to match the first tire/wheel position, and five minutes overall, to match all four tire/wheel positions. If it takes longer than two minutes to match the first tire and wheel, or more than five minutes to match all four tire and wheel positions, the matching process stops and you need to start over |
09-08-2011, 08:05 PM | #8 | |
knows 2 facts about ducks
09-08-2011, 08:21 PM | #9 |
Drives: 2011 Camaro SS/RS LS3 Join Date: Aug 2010
Yeah, I'll get around to it...
09-10-2011, 05:01 AM | #10 |
UPDATE i went to a local dealer had him do it it was free of charge . Thank you ever one for your help
09-16-2011, 08:08 PM | #11 |
Drives: 2016 SS Join Date: Jun 2011
The 2011 manuals were changed part way through 2011. Mine does NOT include the instructions about dropping tire pressure to reset - ONLY by using the relearn tool. If you check the online manual on the chevy web site it is the same:
http://www.chevrolet.com/assets/pdf/...aro_owners.pdf What I would like to know is for cars after that change, from late in 2011, does the tire pressure change work anyway and is just not documented anymore, or did they really make a change to the system that stopped that option from working? I don't know how we will find out until one of us tries it. HDRDTD - did you try it and it did not work? Sorry if that should have been clear to me already, I'm just trying to make sure I understand. |
03-19-2012, 06:56 PM | #12 |
Drives: 2011 Camaro 2LT/RS Black Join Date: Nov 2011
I got a 2011 and it worked on mine.
03-19-2012, 08:09 PM | #13 |
Emerald Coast Camaros
Drives: A lot of show, not much go. Join Date: Mar 2011
Wow, a Nightfall thread. Weird.
03-19-2012, 08:47 PM | #14 |
Hmmmmmm.....I really find it interesting how some think they know everything but they really don't.
I just put my 20's back on my car this weekend. And Reset my TPMS's on my 2011 by lowering the air pressure and they work great. |
Similar Threads | ||||
gm tpms reset tools cheap | camaro1 | Wheels and Tires Talk Sponsored by The Tire Rack | 13 | 11-24-2017 02:32 PM |
TPMS issues - finally a response! | Nine Ball | Wheels and Tires Talk Sponsored by The Tire Rack | 157 | 04-17-2015 02:27 PM |
Help!!! TPMS install onto TSW Nurburgrings | Avalnch | Wheels and Tires Talk Sponsored by The Tire Rack | 13 | 03-09-2011 06:44 PM |
Mounting OEM TPMS on 3-piece wheels | Flux | Wheels and Tires Talk Sponsored by The Tire Rack | 12 | 03-07-2011 06:59 PM |
What will a GM dealer exactly do when programming TPMS sensors on the car?Wont Reset! | 55Designs | Wheels and Tires Talk Sponsored by The Tire Rack | 13 | 02-20-2011 08:02 PM |
