02-10-2018, 05:22 PM | #1 |
Rear tire size
Will a 315/35/20 on a 10 inch 35mm offset rims fit on stock suspension ?
02-10-2018, 08:15 PM | #2 |
Drives: 2016 2SS Convertible Join Date: May 2012
The 315/35/20 is a little wide for a 10 inch wheel and it is 1" taller than factory spec. I don't know if that could cause problems with your traction control if the fronts aren't close to the same diameter.
People report rubbing with 305/35 tires so you will probably have to relocate the driver's side wiring harness and then you still might have to use a spacer for clearance. |
02-11-2018, 06:19 AM | #3 |
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500 Join Date: Mar 2012
Well I just found out yesterday that since I put on 285/35-20's the tire does in fact rub the liner when you turn either way, they do clear the strut tower but barely, I am running 20X10 +23 and I had to add a 3mm spacer to be double sure about the strut so now I plan on putting 275/35-20's on all four corners, don't get me wrong that I like the way the 285's do look good but I don't want create a problem down the road.
02-11-2018, 10:54 AM | #4 | |
