#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Forced Induction Discussions
Old 11-07-2020, 09:31 PM   #1
Kerry
Drives: 2019 2SS Camaro
Break out harness
So its supposed to put the 1 bar out of the manifold to read the boro. Have the 3 bar in the manifold. But the one bar does nothing. unplug it and no change in the reading. Unplug the 3 bar and it changes the baro reading. So i dont understand.
The problem is the baro keeps changeing. Normal start up here is 14.1 but in a short time it goes to 15.9. I know thats not right.
I just got the nguage and when it reads boost the boro goes down. Starts at the same 14.1 or so and as boost comes up the bro drops as far as 12.5. Again not right. What gives and what am I doing wrong? Do I have a bad harness? I can only find 3 different boro places to log in hp tuners and none make any difference
Kerry is offline   Reply With Quote
Old 11-10-2020, 08:45 AM   #2
Juiced1
Drives: 2012 2SS CAMARO 45th
That 1 bar is only for the Pratio. Any other baro reading is going to be the main map sensor. Since technically that map sensor is actually part of the maf.
Juiced1 is offline   Reply With Quote
Old 11-14-2020, 08:49 AM   #3
Kerry
Ok let me ask this. When logging runs does the baromtric pressor move? Mind does like over 2 points sometimes. just wondering if I have a problem?
Old 11-14-2020, 08:56 AM   #4
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
So, what do you have for a setup? On a PD blower, the MAF reads the baro as Juiced alluded to and it works fine. But on a centri setup, if the MAF is pressurized then your Baro readings are incorrect and screws up your P-Ratio. I’m assuming you used a breakout harness to take the baro reading away from the MAF. It shouldn’t be changing 2 full points under boost IMO.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
Joshinator99 is online now   Reply With Quote
Old 11-14-2020, 11:16 AM   #5
Kerry
Yes its a procharger,with the breakout. It will read 14.1 at start up. Thats normal for here. Then as the car gets warm it just out of no where jumps to like 15.9. Then as boost comes on it will drop. If its 14.1 it can drop to 12.5 if its reading 15.9 it might drop to 14. Makes no sense to me. Why would it move and does other cars do this or do I have a problem?
Old 11-14-2020, 11:17 AM   #6
Kerry
Car seems to run fine. afr stays about the same but it does jump around alot.
Old 11-14-2020, 11:19 AM   #7
Kerry
Boost is measured from the boro reading correct?
Old 11-14-2020, 12:49 PM   #8
Joshinator99
Partially. Boost is from MAP (Manifold Absolute Pressure) minus baro reading. Baro is your outside barometric pressure and the only way it changes is based on weather and altitude.
So, for example, if your MAP is 28.5 and your baro is 14.1, then you’re making 14.4 psi boost.
Old 11-14-2020, 01:23 PM   #9
Kerry
Thats what I thought so when the boro is moving around a couple psi then the reading is incorrect. Seems like it would change the afr, I gues cause its maf only so thats keeping the afr in ck
Old 11-17-2020, 06:08 AM   #10
wnta1ss
Drives: 2017 Camaro 1SS
Have to suspect a problem with your harness or sensor, no change from unplugging the sensor is a red flag. The baro reading should stay steady with that kit, that's the whole purpose of it, to ignore the bad baro readings that come from the MAF when it's downstream of the compressor. I had the baro breakout with a centrifugal supercharger, checked a log and the baro reading was steady at 14.5 (low altitude track). Illustration below, notice how the baro reading is steady despite differing throttle, rpm, and manifold pressure points.
wnta1ss is offline   Reply With Quote
Old 11-17-2020, 08:59 PM   #11
Kerry
Attachment 1050246
Thank you so much for your reply. I emailed dsx and they looked at my tune and the map sensor was set to na-map but should have been set to na-tiap. Works like a champ now. Thanks!!! when I unplug the 1 bar it reads 0 now. Plug it back in and reads 14.5 da is really good right now.
