Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 02-02-2013, 08:02 PM   #1
HIGGS85Z28
Drives: 1985 chevy camaro z28
battery drain
another issue im having is my battery is draining but i have a new battery and a new alternator any suggestions will help 85z28
Posted from Camaro5.com App for Android
HIGGS85Z28 is offline   Reply With Quote
Old 02-02-2013, 08:06 PM   #2
AKA-51
Drives: Ellie
t
AKA-51 is offline   Reply With Quote
Old 02-02-2013, 09:30 PM   #3
HIGGS85Z28
t?
Old 02-03-2013, 10:44 AM   #4
lawdog
Drives: 2010 SSII w RS & Sunroof Yellow
Location: West Suburbs of Chicago, in a Courthouse Somewhere
You have a positive wire that is grounding out somewhere. it will be a wire that gets juice even when the car is off and light switch is off. These things are difficult to find and often require a good mechanic. A good mechanic can use a meter to possibly locate what is drawing juice by testing each circuit. I would suggest looking at the wires between the battery alternator and starter first, then look at the wires running under the car to the back end and next to the ones running to the interior lights, locks...
Good luck
If you have any kind of an aftermarket alarm system, disconnect it from its power sources and try that first, a lot of times the brains to those units go bad after awhile and draw juice!
lawdog is offline   Reply With Quote
Old 02-04-2013, 12:06 AM   #5
gutterball
gutterball's Avatar
Drives: 2014 1LS M6 Supercharged
Send a message via AIM to gutterball
To find out where the drain is, disconnect the Neg. of the Batt. Go buy yourself a cheap VoltMeter, (any Auto Store, Walmart, Target). With the Ign off, Set the VoltMeter to Amps (1 Amp), Put the Neg of the Meter to Gnd and the + to the Neg of the Batt. If you read any type of Current, maybe 10 mills or more, you can isolate the circuit by pulling your fuses out, 1 at a time. When you get to the bad circuit, the reading on the Meter will go almost to Zero. It might be the Radio circuit or the Head Lights, Tail Lights, but now you know where to start looking
gutterball is offline   Reply With Quote
Old 02-09-2013, 05:17 PM   #6
one92rs
one92rs's Avatar
Drives: 1992 chevy camaro rs
or an easier way. I used a trailer light on mine. hooked it in between the neg cable and the neg term on the battery. if there is a draw the light will light up. just had this problem on mine. turned out to be the stereo.
one92rs is offline   Reply With Quote
Old 02-10-2013, 10:46 AM   #7
gutterball
gutterball's Avatar
Depends on how bad the drain is. It could be small and not enough to light the bulb.
Old 02-10-2013, 12:30 PM   #8
one92rs
one92rs's Avatar
1 volt will light the bulb very dim. but it will light it.
Old 02-13-2013, 09:04 AM   #9
Heaven_is_inferno_orange
Savage Setsuna
Heaven_is_inferno_orange's Avatar
Drives: 16' 2SS, 12 ZL1, RIP Sasuke
Send a message via MSN to Heaven_is_inferno_orange Send a message via Yahoo to Heaven_is_inferno_orange
Parasitic draw test. Connect an Ammeter in series in at battery. Make sure all domes lights, trunk list, ect are off. Give it 10-15 minutes for the PCM to go to sleep and check amperage reading. .050 A. And under is good. If you have aftermarket electronics that's always the best place to start if you have a parasitic draw. Pull a fuse and if the amperage drops you've got the culprit.
Heaven_is_inferno_orange is offline   Reply With Quote
Old 08-22-2015, 08:54 AM   #10
Jackass
Doing what I like to do
Jackass's Avatar
Drives: 1963 Landrover
Sorry to bring an old thread back tolife again
But that's because it happen to me last Thursday night I found my Z making a crippling sound in the garage , I just realized that the battery way dead , not doors could be open by the remote , no lights , radio , nothing on
So I'm taking the car to the dealer this morning on a flatbread tow truck
Does anyone really ever came to the conclusion on how this things continue happen to these cars ?
Jackass is offline   Reply With Quote
Old 08-22-2015, 09:23 AM   #11
Normagene
Normagene's Avatar
Drives: 2013 Ashen Gray M6 ZL1
Every time I put her in the garage for a couple days or more I pop the hood and connect my Battery Tender Jr. Floats the battery at full charge. Battery never died, but that's the point, too many horror stories on dead batteries. I have aftermarket taillights that are notorious for draining the battery. Get one at Walmart, order on-line and pick it up at store. For some reason it's like five bucks cheaper than buying it at the store.
Normagene is offline   Reply With Quote
Old 08-22-2015, 08:11 PM   #12
Jackass
Jackass's Avatar
Just had the car checked out at the local dealer , they ran some tests and said that's a bad battery , some cell went bad and messed things up
New battery in ,oil change done and back to normal , I hope !
The car is only one year old , 4200 miles .
Old 04-05-2018, 06:16 PM   #13
Pagliaro
RIP Betsy ( Vitara )
Pagliaro's Avatar
Drives: '11 SGM 1LT/RS
Send a message via AIM to Pagliaro Send a message via MSN to Pagliaro Send a message via Yahoo to Pagliaro
Happening to me right now just recently had a re and re.
First retrofitted 2014 mylink.
Pagliaro is offline   Reply With Quote
Old 04-09-2018, 06:54 AM   #14
joelster
joelster's Avatar
Drives: '94 Z28+ '15 Z/28
If you know the car is going to sit for long periods of time, disconnect the battery.
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C
1980 Z28- resto-mod project
1979 Y84 Trans Am
1986 IROC-Z
joelster is offline   Reply With Quote
