Old 11-22-2014, 10:10 AM   #1
AZ-ZL1
Dry Heat My @ss
AZ-ZL1's Avatar
Drives: 2012 ZL1 SUMMIT WHITE
New NHRA Rule...BS
Got kicked off the track last night after my 1st pass for running a dismal 11.41 (along with several other cars). Tech informed me that any UNALTERED vehicle, 2008 or newer, can run 10.0/135 mph or slower. All others, without a cage, are limited to 11.5. Even a CAI or tune disqualifies you as an unaltered vehicle. Only tire modifications are allowed.
There should be an exception for cars like ours. I do not believe the mods necessarily make our cars any less safe.....maybe the driver but I've watched several 12 sec cars smack the walls.
No cage for me, guess the strip is now off-limits, which stinks.
Anyone else having the same issue as of late ??
2012 #1765: Xpel Clear Bra, 15% Tint, M2W, LPE GT9 Cam, Ported Heads & Snout, Upgraded Valve Train, 90mm TB, LPE Dual Fan HX, 2.55 Upper, 9.1 Lower (18%), Id850's, KB BAP, Roto-fab CAI, AR Stainless Headers, 673 rwhp, A6, Nothin but Fun!
AZ-ZL1 is offline   Reply With Quote
Old 11-22-2014, 10:25 AM   #2
Mean Green Z28
Drives: 2010 2SS
didn't know about the unaltered vehicle clause. hmmm.... I used to just do a private rental with friends when I had my old Camaro. hate waiting in line at the local t&t with a bunch of imports who seem to break and oil down track almost every run.
Typing fat fingered on my GS3...excuse any sfelling mitcakes
2010 2SS - CAI Intake, ADM Scoop, RotoFab Washer relo. LT Headers and off-road pipes, X-pipe, Muffler Deletes, ZL1 Spoiler, Technostalgia Tail-lights
'98 T/A (Sold) - Forged 6.0ltr, MS3, P&P'd Heads/Valves, 90MM FAST/TB, Headers, 3" Y-pipe, 4" Mufflex Catback. Koni Adjustables w/GC coilovers (550/175), Strano Sway Bars
'94 Z28 (Sold) ... LS1 swap (basically same setup as the T/A), TH350/3500 stall ... swapped it all into the T/A
-- >> Some of my Projects My Fquick Page
Mean Green Z28 is offline   Reply With Quote
Old 11-22-2014, 10:32 AM   #3
402
Drives: Camaro
Rules are rules.
I don't see a problem with them.
402 is offline   Reply With Quote
Old 11-22-2014, 10:40 AM   #4
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
A long time ago it used to be 12.0 or faster gets a cage.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - Stock
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 11-22-2014, 10:43 AM   #5
Mikes fast ss
Slowhawk Built
Mikes fast ss's Avatar
Drives: 2010 Supercharged SS
By the list of mods in your sig you are heavily altered.
That rule only applies to cars straight off thr showroom floor.
Rule is not new.
9.21 @ 149 Slowhawk Performance
Mikes fast ss is offline   Reply With Quote
Old 11-22-2014, 10:48 AM   #6
AZ-ZL1
Dry Heat My @ss
AZ-ZL1's Avatar
Originally Posted by 402 View Post
Rules are rules.
And they can be impractical and unreasonable as technology changes...something as minor as a pulley swap can make these cars run faster than 11.5. Does not make the car any less safe.
Old 11-22-2014, 10:51 AM   #7
AZ-ZL1
Dry Heat My @ss
AZ-ZL1's Avatar
Rule is not new.
After a year and several "Friday Night Drags", I guess it is newly enforced ?? I thought it was recent. Thanks
Old 11-22-2014, 10:56 AM   #8
Mikes fast ss
Slowhawk Built
Ah, the enforcement part... that's a whole separate issue. Kinda of joke. Some tracks enforce it others don't. No consistently.
I feel you on that.
Old 11-22-2014, 10:57 AM   #9
Mean Green Z28
Drives: 2010 2SS
nope, they did change from 12 to 11.5 but they've always enforced it at my local tracks. I was given a warning once and told I could race that night but need a cage if I came back. wasnt that much faster than 11.5 at that time
Old 11-22-2014, 11:51 AM   #10
402
Drives: Camaro
Technically it does. With et comes mph, your car was designed to withstand crashes below 50mph give or take. Double that and see how "safe" your car is.
Old 11-22-2014, 11:59 AM   #11
AZ-ZL1
Dry Heat My @ss
AZ-ZL1's Avatar
hmmmm...The "safety" difference between an 11.6 @ 120 mph and 11.4 @ 125 is insignificant....... or my PB, an 11.08 @ 128 for that matter. I don't "buy" your argument.
Old 11-22-2014, 12:28 PM   #12
402
Drives: Camaro
My first semtense was just a statememt. You are already doubling what these cars were designed to withstand and that's stock. Rules are in place to keep people safe if the rules didn't achieve that they wouldn't have rules.
Old 11-22-2014, 12:48 PM   #13
SpeedIsLife
Drives: Current Camaro-less
The reason for this rule and you being forbidden from racing the car until you cage it is because your car was certified from the factory with it's stock safety equipment at the stock power levels. The NHRA is protecting itself, and the track, from lawsuits. They already have given a very large amount of leeway in allowing modified cars to run without additional safety equipment down to 11.5.
By signing the safety form and submitting to a technical inspection you are attesting to the fact that you have read the NHRA rules (which clearly you have not), understand them (which clearly you don't care to) and are consenting to all provisions therein. If you wreck and cause injury to yourself, another racer, spectator, track official, etc because your car had a catastrophic failure due to power levels/ times faster than NHRA regulations stipulate and you concealed it? Lawsuit city, population YOU.
The rules exist for your safety and the other racers, they are not there to ruin your fun.
Do yourself a favor and either cage it (you can get NHRA cert'd cages with removable side bars) or take some of the power out of it so it's slower than 11.49, those are your only two options if you want to race the car.
SpeedIsLife is offline   Reply With Quote
Old 11-22-2014, 01:18 PM   #14
Mean Green Z28
Drives: 2010 2SS
... or go really fast until the 1/8 mile and coast to the 1/4
