Old 04-28-2013, 01:19 PM   #1
Briand069
Drives: 1997/1969 Camaro's
Oil leak and what dealer did
Hello,
Picked up my car Friday from the dealer after they had it all week to fix the oil leak or leaks. Original diagnosis was 3 leaks: Rear cover gasket/seal, oil pan gasket and also oil cooler gasket. Well, got under there today and first thing I see is oil on the cooler and pan. I continue looking around and I can definetly see they removed the transmission but I cannot tell if the pan or cooler was removed. Also, now looks like tranny fluid leaking from maybe one of the cooler lines. So, I've cleaned up all the oil I can see and will check again in a couple days for leaks. My question to anyone that has had the pan gasket replaced do you know if the front suspension had to be dropped to replace it? I can't see anything on mine that looks like it was unbolted but maybe they can get the gasket by lifting the engine some?
Brian
1969 Camaro LT1 4L60E
2010 Camaro 2SS/RS 6spd
Briand069 is offline   Reply With Quote
Old 04-28-2013, 07:06 PM   #2
2011 SS SLP ZL427
2011 SS SLP ZL427's Avatar
Drives: 2011 SS ZL427
If they had to change the oil pan gasket they would have had to drop the front suspension, being they also did the rear main seal cover thats why you see evidence of the tranny being removed, being you cleaned everything up, watch very close now for any new leaks that they could have caused because alot is involved in these 3 repairs they did to your car.
2011 SS SLP ZL427 is offline   Reply With Quote
